motors browning out PIC
Results 1 to 14 of 14
    Default More
    Quote Originally Posted by mbw123
    Thanks guy's. I turned off BOD and MCLR like sayzer suggested. It is better but there are still errors. I bought the Schottky diode and the caps like charles suggested, but when I wired it up it didn't work. I measured the 10uF cap with my multimeter and it started at the correct voltage, but before long it went down to zero. How does this work if the capacitor goes to zero and the PIC gets no power? Thank you for the help.
    -Mike
    Hi Mike,
    Put the diode in series with the power to the PIC, The capacitor hooks to the Power pin and to ground, on the diodes cathode side. The diode prevents the capacitor from discharging back into the motors, you may need a larger capacitor than 10uF. The only danger I see is if the capacitor is too large PIC might not boot due to too slow of power up. If this still fails, think good thoughts about using rechargable batteries instead of the Cap.
    JS
    Sep 2005
    Campbell, CA
    No, you can use a capacitor as large as you want. There will be NO problem during start up.
    There is one drawback to this method, however - The Schottky diode will have a voltage drop of about 0.5V. This means that the PIC will see a power supply voltage of 0.5V less than the actual power supply.
    Charles Linquist
    Default Super
    Quote Originally Posted by Charles Linquis
    Thanks Charles,
    I wasn't sure about that one :-), in that case use a BIG one, or use a seperate PS for the PIC, Oh one more thing, take your PIC power and ground directly from the batteries, or power supply, not from the motors power bus.
    Jul 2006
    Thanks again guys, you are very helpful. One last question. I bought the Schottky diode as suggested and it has a "cathode band" on it. Which direction should I put the diode in, the cathode band side facing the PIC or facing the power?
    I'll be sure to follow all of your advice.
    -Mike
    Sep 2005
    Campbell, CA
    Cathode toward the PIC.
    Charles Linquist
    Jul 2006
    Thank you everyone. I got it working!!
    -Mike
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. Serial Pic to Pic using HSER
  5. PIC chips, stepper motors and precision
    By Demon in forum General
    Last Post: - 6th February 2005, 16:28
