16F877a Interupt driven Hserin
Results 1 to 3 of 3
    Default 16F877a Interupt driven Hserin
    Hi all, after suffering with my previous problem I was wondering if someone
    has a sample code to do some interupt driven Hserin
    I need to do the following:
    Read a serial string at 9600bd containing a start command "#" then 5 variables of each 3 Decimal digits separated by a ";" (let's say byte in decimal presentation)
    then I need to read 5 AD values on RA0-RA4
    Then i need to write those variables to an LCD display 4x20)
    and send them back and to some the serial port using HSEROUT
    finally I need to write some variables or bits to some hardware
    ports like (PortB,PortE,PortD)
    Mean while I may receive an updated string on the serial port using HSERIN
    If I use the following example from Mister E to play with Hserin and interupt
    it works,
    ' Serial communication definition
    ' Using internal USART and MAX232 to interface to PC
    RCSTA = $90 ' enable serial port,
    ' enable continuous receive
    TXSTA = $24 ' enable transmit,
    ' BRGH=1
    SPBRG = 103 ' set baudrate to 2400
    ' Alias definition
    RCIF VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty)
    TXIF VAR PIR1.4 ' Transmit interrupt flag (1=empty, 0=full)
    OERR var RCSTA.1 ' Overrun error
    CREN var RCSTA.4 ' Continuous receive
    ' Hardware initialisation
    pause 10 ' safe start-up delay
    if oerr then ' Overrun error?
    cren=0 ' clear it
    cren=1
    if RCIF then ' incomming data?
    TXREG=RCREG ' take it, send it
    while TXIF=0 ' wait untill transmit buffer is empty
    wend
    But as soon as I add multiple commands like Hserout,LCDout,etc...
    I miss some values on the HSERIN or get stucked on the "WAIT" command
    Any help or example how to do a proper interupt driven HSERIN while
    still displaying on the LCd and HSEROUT ?
    I doubt that a tight loop and a register polling method will work. try working around the example 2 of this one
    http://www.picbasic.co.uk/forum/show...1&postcount=11
    In the ISR you may set a flag to tell the main to read the ADCs. To avoid waste of time and void some interrupts, i would recommend to set/read the ADCs register instead of using ADCIN. A short asm Delay loop, or use internal timer, OR a tight PAUSEUS x loop for your acquisition time.
    The use of instant interrupts OR asm, could be the best and smarter choice. Rule #1, never waste your time in ISR... this is what 'Wait' do ?.
    Let us know what's happen now.
    if someone has a sample code to do some interupt driven Hserin
    Quite a few...
    http://www.picbasic.co.uk/forum/sear...ess&query=rcif
    --and--
    http://list.picbasic.com/cgi-bin/boa...ALL&query=rcif
  1. Help! My 'interupt', erhm ...only interupts the one time?!!!
    Last Post: - 2nd November 2009, 13:49
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. 16F877A HSERIN problem
    Last Post: - 30th October 2006, 03:51
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
