As is clear from above, I have never used verilog ...., for completeness this not so pretty approach still works
;Datum[6:4] = 2
Datum.6=0
Datum.5=1
Datum.4=0
;IF PORTB[5:1] = 3 THEN
If (PORTB & $3E) = $06 THEN
OR you could blast the first type with inline ASM
;Datum[6:4] = 2
Datum var byte
movlw 0x20 ; b00100000 new values
xorwf _Datum, W
andlw 0x70 ; b01110000 mask values
xorwf _Datum, F ; bX010XXXX
Others might have a cleaner method?
EDIT - added comments to ASM routine
