Help me about communicating PIC with cellular phone...
Results 1 to 14 of 14
    Nov 2006
    Yes I had cross connected RX and TX of the phone and pic. I don't think the problem is because of it.
    Nokia is working with TTL Logic so it gives high for 3.3v (so 5volt too) and low for 0 volts; So I think max232 is not needed to use here. Because it is using for RS232 which is working with 12Volt.
    Dec 2005
    Quote Originally Posted by d_hamen
    You still need to invert the logic. The PIC UART is uninverted. You either need to use SerIn/SerOut so you can invert in your firmware or you need to add two inverters (e.g. using the comparators as suggested in the link I gave earlier).
    I'm not sure what you mean by "so 5volt too" but 3.3V is inadequate if you are using the PIC at 5V Vdd. Port C has Schmidt Trigger buffers which need 0.8*Vdd for a logic High (0.8*5V=4V). If you use SerIn/SerOut or DebugIn/Debug on pins that have TTL buffers, 3.3V should be OK.
    Dec 2005
    Are you sure about those 7250i pins? Everything I can find indicates the 7250i has USB and IR but there's nary a mention of a serial connection.
    What is FBus?
    Nov 2006
    FBUS is a protocol that nokia phones are using. It is same as AT commands but a bit complex.
    I made the program as you said. but it doesn't work. FBus Rx&Tx means it is supported for serial connection for Nokia 7250i.
    INCLUDE "modedefs.bas"
    DEFINE OSC 4 ' Define clock Oscillator Frequency at 4Mhz
    DEFINE HSER_CLROERR 0
    OUTPUT PORTc.6
    INPUT PORTc.7
    PORTc = %00000000 ' Initial state of PORT C
    ' Make a call
    serout2 portC.6, T9600, ["ATZ",13,10] ' Reset the phone
    Pause 1000
    serout2 portC.6, T9600, ["ATDT",34,"+905448515247",59,34,",129",13,10] ' Make a call for 15 sec.s 59 is ;
    PAUSE 15000
    serout2 portC.6, T2400, ["AT",13,10] ' Finish the call
    PAUSE 1000
    GOTO Main
    Thanks...
    Jan 2006
    Istanbul
    Himmm,
    I now where this phone number comes from!
    Dec 2005
    You need INVERTED logic -try N2400.
    And, assuming you use +5V to power the PIC, you are still using PortC which needs 4V for a logic high so the 3.3V from the Nokia will not be detected. Look at the Electrical Characteristics section of the datasheet.
    Do you have a URL that explains the FBus connections and protocol?
    Dec 2005
    I found numerous links about F-Bus. If they are accurate, you are pretty far off base.It runs at 115200bps. Here's a schematic of the interface hardware...
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. communication of pic 18f4520 and cell phone
    By Alisha in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 12:47
  3. Replies: 288
    Last Post: - 25th August 2008, 17:53
  4. Replies: 2
    Last Post: - 12th September 2007, 09:08
