Voltage output from PIC16f628A
Results 1 to 15 of 15
    bennamanna's Avatar
    bennamanna Guest
    Smile
    Gday again,
    Thanks for that info. I changed the PR2 as per your calculation. It still does not seem to give the same value as I enter in the terminal application. If I am correct in my coding, if I send it 100 with a terminal app 100 should display on the LCD and it should set the duty cycle to 100. This is not the case. It says 34 on the LCD and reflects that in the duty cycle.
    Any ideas?
    Ben
    I don't know wich terminal software you're using but be sure it send ASCII character and use the right modifier in your Serin/Serin2/DEBUGIN/HSERIN line.
    Look for # or DEC.
    Also, make sure your terminal software don't send cr and lf character.
    Once you're sure of it, you should have better results.
    If you send 100 and receive it correctly, you should have a 16% duty cycle.
    bennamanna's Avatar
    bennamanna Guest
    Smile
    Gday,
    I am using serial communicator that is with microcode studio. I cant see a setting to ensure it is sending ascii. I made sure it was not sending cr and it made no diference.
    The code I am using is below.
    NCLUDE "modedefs.bas" ' Include serial modes
    SI VAR PORTB.1 ' Serial Input pin
    B0 VAR BYTE
    Define OSC 10
    Define LCD_DREG PORTA ' RA0..3
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA ' RA6
    Define LCD_RSBIT 6
    Define LCD_EREG PORTA ' RA4
    Define LCD_EBIT 4
    Define LCD_BITS 4
    TRISA = 0
    TRISB = 0
    CMCON = 7
    Pause 1000 ' Wait for LCD to startup
    duty VAR BYTE ' Duty cycle value (CCPR3L:CCP3CON<5:4>)
    TRISB.3 = 0 ' Set PORTB.5 (CCP3) to output
    CCP1CON = %00001100 ' Set CCP3 to PWM
    T2CON = %00010101 ' Turn on Timer2, Prescale=4
    PR2 = 155 ' Set PR2 to get 1KHz out
    duty = 100 ' Set duty cycle to 20%
    loop:
    SerIn SI,T9600,,duty
    if duty > 625 then
    LCDOut $FE,1 ' Clear LCD screen
    LCDOut "Duty to great" ' Display line 1
    goto loop
    CCP1CON.4 = duty.0 ' Store duty to registers as
    CCP1CON.5 = duty.1 ' a 10-bit word
    CCPR1L = duty >> 2
    'duty = duty + 5 ' Increase duty cycle
    LCDOut # duty ' Display line 1
    GoTo loop ' Do it forever
    Any other ideas why it is not receiving the same as I send it?
    Ben
    Jan 2006
    Istanbul
    hi Ben,
    Since our PICs are serial processors, at least for now, and must execute the instructions serially, that is to say one line or instruction at a time, you will never get Serin and Serout commands working at the same time.
    If you use hardware USART, then it will be working in the background, so that you can receive something at the same time you send it.
    As i said before... look for # modifier... it convert your ASCII string to a DECIMAL value.
    bennamanna's Avatar
    bennamanna Guest
    Smile
    Hi sayzer,
    Thanks for your reply. I did not think that my code was trying to use ser in and out at the same time? Could you indicate where I am doing this? Thanks mate.
    mister_e,
    Thanks once again. I'm sorry if I'm making you repeat your self. As stated before I am a beginner. I had however already played with # in my code. I tested it with and without. With out # all i get is jargon.
    Ben
    1. your prescaler is not set to 1:16 as said in the calc. Now, it's set to 1:4. Have a look in datasheet section 8.0 register 8-1 T2CON. you'll discover you need to use T2CON=%00000110
    2. duty=100 set a duty cycle of 16%... still as per the calc. 20% Duty=125
    i think it's invalid.
    you should try
    SerIn SI,T9600,#duty
    In Microcode Studio serial communicator, you have access to the settings. Right to 'send' button there's a little arrow.. click on it, go to line terminator, then check 'No terminator'
  1. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 20:10
  2. What's the voltage on output pin when it's HIGH?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 16:06
  3. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  4. Serious Serial Situation Setbacks...
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
