Voltage output from PIC16f628A
Results 1 to 15 of 15
    bennamanna's Avatar
    bennamanna Guest
    Question Voltage output from PIC16f628A
    Hi all,
    I am very new to pics and programming. I have a PIC16f628A of which I want to use for a project. I wish to have 2 voltage outputs. One 0-2.5v and the other 0-5v. I wish to be able to to send commands from a PC via rs232 to set these voltages. I am using picbasic for the project. Can anyone give me some guidance or some code of a similar project that I can learn from? The pc coding is fine. I am using VB and comm control.
    Ben
    Tons of different way
    Scheme 1:
    Use HPWM to produce your 0-5 volt
    Use a op-amp and use the Vref signal to produce you 2nd 0-2.5 volt. If you can deal with the resolution.. it works.
    Scheme2:
    Use HPWM for your 0-5 volt
    Create a timer based PWM to create the second PWM channel
    Scheme3:
    Use 2 DAC. MAX437 is simple and cheap
    Scheme4:
    Use Darrel Taylor Multi SSPWM. So you may produce few different voltage output.
    Scheme5:
    Create you own multi PWM output based on Timer interrupts.
    Scheme6:
    Use a PIC with 2 CCP module.. hence two PWM output. 16F876,16F877 and the list is long enough to fill the screen here
    Scheme7:
    Use 2 PIC with 1 PWM. 1XPIC16F628 + PIC 12F683 talking together.
    There's some others but it should be enough to start?
    bennamanna's Avatar
    bennamanna Guest
    Default Voltage
    Gday,
    Thanks for your reply. I am testing some of your methods. I have a few queries.
    1. This voltage i require is to be read by a vehicle ecu. If you use PWM will it see that as a voltage or will it see the pulses?
    2. I have put together some code to test the PWM output. It is giving a PWM signal as expected but when I input a figure in a terminal it does not put the same figure to the display or PWM output. It does change but not as expected. Any ideas why?
    INCLUDE "modedefs.bas" ' Include serial modes
    SI VAR PORTB.1 ' Serial Input pin
    B0 VAR BYTE
    Define OSC 10
    Define LCD_DREG PORTA ' RA0..3
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA ' RA6
    Define LCD_RSBIT 6
    Define LCD_EREG PORTA ' RA4
    Define LCD_EBIT 4
    Define LCD_BITS 4
    TRISA = 0
    TRISB = 0
    CMCON = 7
    Pause 1000 ' Wait for LCD to startup
    duty VAR WORD ' Duty cycle value (CCPR3L:CCP3CON<5:4>)
    TRISB.3 = 0 ' Set PORTB.5 (CCP3) to output
    CCP1CON = %00001100 ' Set CCP3 to PWM
    T2CON = %00010101 ' Turn on Timer2, Prescale=4
    ' Use formula to determine PR2 value for a 1KHz signal,
    ' 4MHz clock, and prescale=4. (4E6/(4*4*1E3))-1=249
    PR2 = 249 ' Set PR2 to get 1KHz out
    ' Use formula to determine CCPR3L:CCP3CON<5:4> value for
    ' ends of range 20% to 80%. (249+1)*4*0.2=200 (20% value)
    ' (249+1)*4*0.8=800 (80% value)
    duty = 200 ' Set duty cycle to 20%
    loop: SerIn SI,T9600,duty
    CCP1CON.4 = duty.0 ' Store duty to registers as
    CCP1CON.5 = duty.1 ' a 10-bit word
    CCPR1L = duty >> 2
    'duty = duty + 5 ' Increase duty cycle
    LCDOut $FE,1 ' Clear LCD screen
    LCDOut # duty ' Display line 1
    ' Since the total sweep of duty is 600 (800-200) and
    ' we are adding 10 for each loop, that results in 60
    ' steps min to max. 1 second divided by 60 = 16.67mS
    Pause 17 ' Pause 1/60 of second
    'IF (duty < 900) Then loop ' Do it again unless 80% duty cycle
    'duty = 200 ' Reset to 20% duty cycle
    GoTo loop ' Do it forever
    your CCP definition are fine for 4MHZ, but not for 10MHZ.
    download this tool bellow
    http://www.picbasic.co.uk/forum/showthread.php?t=4994
    it will give you some answer.
    More than likely it will see pulses. You have to convert it to pure DC with a simple RC filter... better if you add a op-amp buffer in between.
    bennamanna's Avatar
    bennamanna Guest
    Smile Voltage
    Gday,
    Thanks again for your reply. I will use a rc filter as you suggested.
    I have downloaded your calc. It looks like it would be verry usefull. As stated I am a beginner ;- ( Could you please step me through what I have to enter in to your calc and my code to fix it? I will learn this way.
    Ben
    you just need to enter the OSC speed and expected frequency. it will give you...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1168&stc=1&d=116295770 1">
    There, you have the
    prescaller => 1:16 => see T2CON setting in your datasheet
    PR2 => 155 => directly
    It also give you the value for 100% duty cycle => 625
    If you want to set different DutyCycle, move the scroll bar at the top right. The duty value will be reported in the 'results' section at the bottom.
    Not much.
  1. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 20:10
  2. What's the voltage on output pin when it's HIGH?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 16:06
  3. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  4. Serious Serial Situation Setbacks...
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
