serin2?
Results 1 to 12 of 12
Thread: serin2?
    Post the whole code here!
    Be sure you disable ALL analog stuff on this 'unknown' S_Pin
    Internal osc or external?
    Did you try to connect your BS2 to your PC?
    May 2006
    ok here is the whole code:
    on the stamp:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM1}
    dat VAR Byte
    DO
    SEROUT 10, 396, ["blink"]
    SERIN 10, 396, [WAIT("t"), dat]
    DEBUG "data: ", DEC dat, CR
    PAUSE 1000
    LOOP
    on the pic:
    define OSC 20
    INCLUDE "modedefs.bas"
    S_in var PORTC.0
    S_Out var PORTC.0
    Led var PORTC.3
    dat var byte
    SerIn2 S_in,396,[dat]
    gosub blink
    SEROUT s_out, T2400,["1234t", dat]
    pause 50
    Blink:
    high led
    pause 10
    low led
    this code only returns me "data: 0" in my debugwindow, if i use the code
    SerIn2 S_in,396,[wait("k")]
    on my pic and remove the SERIN 10, 396, [WAIT("t"), dat] on my stamp it never blinks and it keeps waiting for that "k" the osc is an external 20 mhz crystal
    May 2006
    does anyone know how to fix this? the transmitting does work from stamp to pic but it doesn't from pic to stamp. please help me.
    chriroz, What is the value of "dat"? I don't ever see it getting set...
    Quote Originally Posted by chriroz
    So you didn't post the whole thing?
    Are you sure you properly set the config fuses for your PIC? HS_OSC?
    May 2006
    Unhappy
    OK, THIS IS THE WHOLE CODE:
    on the stamp:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM1}
    dat VAR Byte
    DO
    PAUSE 1000
    LOOP
    on the pic:
    define OSC 20
    S_in var PORTC.0
    S_Out var PORTC.0
    Led var PORTC.3
    dat var byte
    gosub blink
    pause 50
    Blink:
    high led
    pause 10
    low led
    THAT code only returns me "data: 0" in my debug window (witch is already strange.)
    and if i use THIS code (the one i actually need):
    on the stamp:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' {$PORT COM1}
    dat VAR Byte
    DO
    PAUSE 1000
    LOOP
    on the pic:
    define OSC 20
    S_in var PORTC.0
    S_Out var PORTC.0
    Led var PORTC.3
    dat var byte
    gosub blink
    pause 50
    Blink:
    high led
    pause 10
    low led
    than it never blinks and never sees a "k". I really need this problem solved. please post ANYTHING that might help me (i live in european time so i usely have to wait a whole night before i can read your answers and an other day before you read my posts, so post anything you got, i don't have much time left) and my config is HS (in winpic) and define OSC = 20. "dat" is the byte in witch it saves the data received from serin2, isn't it?
    thanks in advance,
    Chris
    May 2006
    I also tried to use an FlowPin and it didn't work. but i found out something strange. after i send my data from my stamp the pin stays high. is that normal? if i give an "low 10" command after it it will get low again
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 20:10
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  4. SERIN2 digit parsing
    Last Post: - 7th January 2007, 23:15
  5. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 09:03
