Creating temp Register
Results 1 to 7 of 7
    Gator_sound's Avatar
    Gator_sound Guest
    Default Creating temp Register
    I wanted to know how to create a temp register in memory. I'm still getting used to using a Pic micro-controller 16f88 and 18f1320. Any help will be greatly appreciated. Thanks
    Jan 2006
    Istanbul
    Hi Gator,
    Can you be more specific?
    Details?
    I am sure you will get your answer.
    TempRegister var byte
    When you say in memory... PIC EEPROM or what?
    Gator_sound Guest
    Hi guys,
    mister_e's got it. I am still in transition mode from assembly to basic,sorry. I was trying to figure out how to send a variable over an RF transceiver and get it from the receiving end. But all I have to do is name a variable so I understand basic a little better.
    Note: Little more info about the RF transceiver. Using the Nordic RF nRF2401 Transceiver and using the shiftin and shiftout method through basic.
    thanks again sayzer and mister_e
    Jan 2006
    Istanbul
    May be it is time to use Serin and Serout.
    Gator_sound Guest
    Hi sayzer,
    What pin do I need to activate Serin and Serout? If I am using a 16f88 or 18f1320? thanks
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 09:47
  5. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 22:54
