Configuring Defines For 8-bit LCD
Results 1 to 25 of 25
    Sep 2006
    i will continue here and not start a new thread.
    I am attempting to have two input values for an A/D conversion.
    I added these two lines and did some changes.
    How do I use the other input analog ports?
    ken
    ' PicBasic Pro program to display result of
    ' 10-bit A/D conversion on LCD
    ' Connect analog input to channel-0 and channel1 (RA0, RA1)
    Define LOADER_USED 1
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    right var word 'Create right to store result
    left var word
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = 0
    ADCON1 = %11000001 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %00000001 ' Configure and turn on A/D Module
    Pause 500 ' Wait .5 second
    loop: ADCON0.2 = 1 'Start Conversion
    notdone: pause 5
    if ADCON0.2 = 1 Then notdone 'wait for low on bit-2 of ADCON0, conversion finished
    ADCIN 0, right 'Read channel 0
    ADCIN 1, left 'Read channel 1
    right.highbyte = ADRESH 'move HIGH byte of result to right
    right.lowbyte = ADRESL 'move LOW byte of result to right
    left.highbyte = ADRESH 'move HIGH byte of result to left
    left.lowbyte = ADRESL 'move LOW byte of result to left
    Lcdout $fe, 1 'Clear screen
    Lcdout "Value right: ", DEC right 'Display the decimal value
    Lcdout $C0, "Value left: ", DEC left 'Display the decimal value
    Pause 100 'Wait .1 second
    Goto loop 'Do it forever
    Sep 2006
    the program still displays the first value at channel 0 , but not a the other channel 1.
    k
    Jan 2006
    Istanbul
    Remove these parts from your code
    notdone: pause 5
    and
    Hangover, Germany
    Quote Originally Posted by lerameur
    left var word
    TRISB = 0
    notdone: pause 5
    Here, inside a forum for PicBasic Pro-Compiler, it is allowed to use some of his commands.
    ADCIN 0,left
    ADCIN 1,right
    ...will do the job for you.
    Jun 2006
    use this for the second line:
    Lcdout $FE, $C0, "Value left: ", DEC left 'Display the decimal value
    Sep 2006
    great its working
    thank you
    ken
  1. 16f688 LCD what have I done wrong
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  3. LCD will not start
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
    Last Post: - 6th March 2005, 01:07
