Configuring Defines For 8-bit LCD
Results 1 to 25 of 25
    Sep 2006
    I thought I was calling the A/D of my controller by using ADCON and ADCIN...
    ken
    Sep 2006
    mainly I just want to use this program but convert it
    in picbasic pro and have a LCD out of the input.
    ‘***Real A to D on the 876****
    program RealAtoDSafe
    Dim data1 as word
    TrisB = %00000000
    TrisA = %00001000
    ADCON1 = %10000100
    while TRUE
    data1=Adc_Read(3)
    If data1 < 4 Then
    data1 = 4
    End If
    PortB = word(data1 >> 2)
    wend
    End.
    Jan 2006
    Istanbul
    Come on lerameur,
    "Dim data1 as word"
    You are also not using PBP!
    Sep 2006
    Like I said, I want to use this program but convert it into PBP
    So from basic to PBP
    I know that this is a pogram that compiles good with microbasic, but I want to use PBP.
    K
    Hangover, Germany
    Angry
    Ken,
    you have written parts of this thread also to the PicList-mailinglist. Just try to understand the answers there !
    I think you have 2 problems in 1 thread:
    1. talking to a LCD by 8 data-lines
    2. Using the AD-modul of a 16F876A
    1.:
    You have to wire PortB.0 until PortB.7 to the signals DB0 to DB7 of the LCD. The E-, RS- and RW-signal can be set to any free digital portpin !
    2.:
    my writing from the PicList:
    Ken,
    you have to make clear, what ports you are using. This is important !
    First you tried PortC.0 as AN4 - wrong,
    then you changed it to PortA ? What pin ?
    Now you use an unknwon language and refers to channel 3.
    So,
    make it easy for us to write your program.
    What Port-Pin is connected to the analog input ?
    Sep 2006
    well I do not want to start a new thread.
    Mainly,I thought that I needed 8 bit to LCD since I wanted 8 bit analog input, but that is not the case, SO I will stay at 4 bit to LCD. which works fine.
    Just my A/D conversion is not working. I have een playing around with ADCON0 AND ADCON1. I looked into PBP manual but no reference of ADCON0, AND THERE IS LITTLE on the spec sheet.
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    adval var word
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000000
    ADCON0 = %00000101
    Low PORTB.2 ' LCD R/W line low (W)
    Pause 500 ' Wait .5 second
    loop: ADCIN 4, adval ' Read channel 4 to adval
    Lcdout $fe, 1
    Lcdout "Value: ", DEC adval
    Pause 100
    Goto loop
    Sep 2006
    as far as port I am using .
    RB4 to RB7 out to LCD
    RB0 RB1 as enable and register select bit
    RA analog input
    k
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 07:13
  3. LCD will not start
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
