Configuring Defines For 8-bit LCD
Results 1 to 25 of 25
    Sep 2006
    so far so good, I do get someting on the lcd. I had wire connection problems
    I found a chip that I have that did A/D conversion. Now I have another problem, my output value is always the same (around 500). It should read the input portC.0 from analog and display its decimal value to the lcd. The analog input is between 2 to 5 volt. I am using a Pic16F876a.
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Define ADC_BITS 10
    Define ADC_CLOCK 3
    Define ADC_SAMPLEUS 50
    adval var word
    TRISC = %11111111
    ADCON1 = %10000010
    Low PORTB.2
    Pause 500
    loop: ADCIN 4, adval
    Lcdout $fe, 1 Lcdout "Value: ", DEC adval
    Pause 100
    Goto loop
    Iran
    why don't you use the internal A/D of your microcontroller?
  1. 16f688 LCD what have I done wrong
  2. first project, and yes, doesn`t work
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 06:13
  3. LCD will not start
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
    Last Post: - 6th March 2005, 01:07
