please try this:
' Set LCD Data port
DEFINE LCD_DREG PORTB
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTB
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTB
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
lcdout $fe,1,"Hello"
LCD Connection
Pin1=Vss: connect to ground
Pin2=Vdd: connect to Vcc=5V
Pin3=Vo: connect to middle pin of the POT(20K) to control brightness
Pin4=RS(register select): connect to micro pins that specify in the software(RB1)
Pin5=RW(Read/Write): connect to ground because we want to only write
Pin6=E(Enable): connect to micro pin that specify in the software(RB0)
Pin7 to 10: No connection
Pin 11 to 14: connect to RB4 to RB7
Pin15: connect to Vcc with a resistor(100 or 200 ohm resistor is good)
Pin16: connect to ground.
pin 16 and pin 16 are for backligh
