Interrupt Or I Am Going To Die
Results 1 to 27 of 27
    May 2006
    Del Rio, TX, USA
    Add this line before your main loop:
    RBIF var INTCON.0
    Add these two lines to your flash subroutine:
    @ MOVE?BA PORTB 'Read PORTB by placing it WREG
    RBIF = 0 'Clear the interrupt flag
    Also, read the pic datasheet on interrupts and under the I/O Ports section. You should find were it mentions both of items added to the ISR.
    kunguz's Avatar
    kunguz Guest
    Question @ Move?ba Portb
    @ MOVE?BA PORTB
    IDE did not recognize this line
    kunguz's Avatar
    kunguz Guest
    Question Retlw Portb.6
    RETLW PORTB.6 when I use this line in top flash block, it doesn't do anything and continue to it's job
    May 2006
    Del Rio, TX, USA
    I shouldn't have been so brief in my first response, so here is a little more explaination. But, you would be well served to learn more about interrupts if this explaination is still confusing.
    @ MOVE?BA PORTB
    This is a PBP internal macro which reads PORTB and moves the value to W register. It results in the asm instruction: MOVF PORTB, W This is the simplist way to read PORTB to end the mismatch which triggers the interrupt on change. No variables and only one line of code are required.
    RBIF var INTCON.0
    This statement assigns the Interrupt Flag (at INTCON.0) used for the PORTB's interrupt on change to the name "RBIF" (which is what it is refered to in the PIC datasheets).
    This statement clears the interrupt flag, which is also required before exiting the interrupt service routine (ISR), or the program will continue returning back to the ISR. No matter what type of interrupt you use, the Interrupt Flag for that particular interrupt must always be cleared before exiting the ISR, or you will end up in an endless loop.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
