Interrupt Or I Am Going To Die
Results 1 to 27 of 27
    kunguz's Avatar
    kunguz Guest
    Question Really can't understand
    So sorry but can you correct my code , I tried everything as in your sample code for PORTB.6 ; But can't get it out.
    By the way my msn is [email protected]. (Olmadı bana burdan yardımcı olursan çok sevinirim, altı üstü bi interruptan çıkamadık)
    Here is my new code below ;
    device 16f84a
    ON_INTERRUPT goto flash
    intcon = %10001000
    input portb.6 ' Bu pinleri sıfırladıktan sonra alıcı olarak ayarlamalısın
    loop:
    high porta
    delayms 200
    low porta
    delayms 200
    goto loop
    disable
    flash:
    WHILE PORTb.6 = 1: WEND
    intcon.0 = 0
    delayms 20
    low porta
    CONTEXT RESTORE
    Jan 2006
    Istanbul
    Couple of things to remember.
    1. It is not a good idea to post an e-mail on the forum. You will get thousands of junks to your e-mail. I suggest that you remove it right away and PM to members instead.
    2. You are not using PBP, but this is a PBP forum
    3. Lets keep this issue on this forum, so that it can be some help to some other members having similar issue.
    Let me try to start by changing the code to PBP first.
    In your schematic, I would use Interrupt on RB0 pin, instead of RB6 pin. May be you should change that first.
    Then, assuming you are now using RB0/Int, we set Intcon Bit 4: RB0/INT External Interrupt Enable bit. Thus, we end up with INTCON = %10010000
    Now the code should look like below but remember it is with PBP statements. You can get around it.
    TRISA =  %00000000     'All output.
    TRISB =  %00000001     'RB0 is input, rest is output.
    INTCON = %10010000     'Enable global (Bit7) interrupt, enable RB0/Int (Bit4)
    ON INTERRUPT GOTO FLASH
    loop:
        PORTA = 255
        PAUSE 200
        PORTA = 0
        PAUSE 200
        GOTO loop
    disable
        FLASH:
            PORTA = 0
            INTCON.0 = 0
    RESUME
    ENABLE
    Also, why do you have to use interrupt?
    May 2006
    Del Rio, TX, USA
    Add this line before your main loop:
    RBIF var INTCON.0
    Add these two lines to your flash subroutine:
    @ MOVE?BA PORTB 'Read PORTB by placing it WREG
    RBIF = 0 'Clear the interrupt flag
    Also, read the pic datasheet on interrupts and under the I/O Ports section. You should find were it mentions both of items added to the ISR.
    kunguz's Avatar
    kunguz Guest
    Question @ Move?ba Portb
    @ MOVE?BA PORTB
    IDE did not recognize this line
    kunguz's Avatar
    kunguz Guest
    Question Retlw Portb.6
    RETLW PORTB.6 when I use this line in top flash block, it doesn't do anything and continue to it's job
    May 2006
    Del Rio, TX, USA
    I shouldn't have been so brief in my first response, so here is a little more explaination. But, you would be well served to learn more about interrupts if this explaination is still confusing.
    @ MOVE?BA PORTB
    This is a PBP internal macro which reads PORTB and moves the value to W register. It results in the asm instruction: MOVF PORTB, W This is the simplist way to read PORTB to end the mismatch which triggers the interrupt on change. No variables and only one line of code are required.
    RBIF var INTCON.0
    This statement assigns the Interrupt Flag (at INTCON.0) used for the PORTB's interrupt on change to the name "RBIF" (which is what it is refered to in the PIC datasheets).
    This statement clears the interrupt flag, which is also required before exiting the interrupt service routine (ISR), or the program will continue returning back to the ISR. No matter what type of interrupt you use, the Interrupt Flag for that particular interrupt must always be cleared before exiting the ISR, or you will end up in an endless loop.
    May 2006
    Del Rio, TX, USA
    Default One Other Thing...
    As Sayzer asked,
    Quote Originally Posted by sayzer
    Using interrupts may just be overcomplicating the application. Could you just pool the I/O line in question in your main loop?
    Jan 2006
    Istanbul
    As Steve repeated,
    May be, a code like the one below could do the job for you, may be.
    TRISB =  %01000000     'RB6 is input, rest is output.
    IN_PIN VAR PORTB.6
    Loop:
        WHILE IN_PIN
            PORTA = 255
            PAUSE 200
            PORTA = 0
            PAUSE 200
        WEND
        PORTA = 0
        GOTO Loop
    Not a real drop-in interrupt compatible code but may work in some cases.
    Try...
    kunguz's Avatar
    kunguz Guest
    Question Finally working but still got a problem
    Thanks alot for your helps and replies;
    It finally works with this code below , but to return to main progress takes approximetly 1:20 minute. I think there might be problem with my schematic; If ISIS is that good, may be simulation thinks about small arcs that is created by button .Which gives a unexpected voltage levels for a short time to the PORTB.6.So PIC interrupts it's self for more then one time.The reason that took so long, might be that. Is this the problem or is it still in software _?
    device 16f84a
    intcon = %10001000
    input portb.6
    loop:
    high porta
    delayms 200
    low porta
    delayms 200
    goto loop
    disable
    flash:
    delayms 1000
    MOVF PORTB, W
    low porta
    intcon.0 = 0
    CONTEXT RESTORE
    kunguz's Avatar
    kunguz Guest
    Question Microchip
    After removing delayms1000 waiting for interrupt takes much shorter time like 1 sec. And I look with an osiloscope in simultion to the portb.6 which i see is a clear 5V. http://ww1.microchip.com/downloads/e...tes/00566b.pdf after reading this I get the feeling like this circuit did not fit for a small pulse width. Is this the problem or am I doing something wrong in programming
    kunguz's Avatar
    kunguz Guest
    Question For a simple click I get 2 change
    After using this new code below, I get value of sayi +2 each time I click.
    device 16f84a
    intcon = %10001000
    dim sayi as byte
    sayi = 0
    loop:
    high porta
    delayms 200
    serout portb.3,16780,[Dec sayi ,13]
    goto loop
    disable
    flash:
    MOVF PORTB, W
    low porta
    intcon.0 = 0
    sayi = sayi + 1
    CONTEXT RESTORE
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
