120 degrees phase shift for three-phase pwm? Any ideas?
Results 1 to 7 of 7
    Feb 2005
    Kolkata-India
    Default What is your application
    Please let me know your application. It is highly doable in PBP-with mixed asm. In fact you can use darretl's routine of multipwm. You need another interrupt that is 3 times your base interrupt frequency and offset the main pwm value into the other. Still you will have offset errors (I suppose), since all the three PWMs are not updated at once. May be okay for driving a motor or UPS in general purpose application. Choice of the PIC is important as if you are playing with soft PWM then you might not have enough computing time left for other jobs.
    Sougata
    Jan 2006
    Istanbul
    Hi Sougata,
    For me, what I need is not sophisticated.
    At first I would like to control the speed of the motor via a pot or couple of buttons.
    Then I can get it modified as I needed.
    So far, mister_e advised me to consider 18F2331 or 18F2431 or 4431. Thanks to him very much.
    I need to use PBP so that I can modify and understand the concept easily.
    Not a very sensitive control I need. Errors are very flexible in my case also.
    But I have no idea where to start. I have good examples in ASM which I am no good at.
    I would appreciate some information.
    declan's Avatar
    declan Guest
    hi, everyone!
    the pwms that i need is very simple: just need to be same in amplitude and frequency as well as duty cycle.
    but have to be 120 degrees offset from each other.
    the pwms will pass through a 3-phase bridge driver and appear as control signals at the gate terminal of the 3-phase inverter.
    the examples on microchip website shows that they are using a lookup table to update the duty cycle. what is a lookup table? how to do that?
    by the way what is soft pwm?
    have a nice day!!
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. PULSOUT emulating phase shift
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 16th May 2004, 19:45
