Button command explanations
Results 1 to 3 of 3
    France
    Default Button command explanations
    Hello,
    I didn't find any explanations about BUTTON command, so :
    in the help I see
    BUTTON Pin,Down,Delay,Rate,BVar,Action,Label
    question:
    Tell me if I can use this Command for this need.
    Assume that somebody depress a DTMF unit, so I am aware of a code is
    present looking to the STROBE input of a MT8870 for example.
    I need to DO a ONE step (right or left depending of the DTMF code)
    and if the guy is maintaining the DTMF strobe... let say after 500 ms
    I will continue to send Right or left order(s) to the Servo motor.
    and as soon the button is released, I will return to the main routine
    waiting for a new DTMF.
    Is the button command can help me ?
    if fact i do not really understand the meanning of autorepeat and the Action
    label interraction.
    Thanks in advance for your good support.
    Francois
    Wink P'tet ben qu'oui, p'tet ben qu'non ...
    Hi, François
    The BUTTON function can be used to look at the StD pin ( 15 or 17 ) ...
    BUT, to work properly, this pin must be regularly scanned to see if a tone couple has been detected ... ( same use as IF pin x = 1 THEN ...but "anti rebond" included )
    OR use an interrupt if the program must react quickly.
    What about TSM , rue des 15 arpents ( or so ...) ???
    Hé,hé !!!
    Futura science invaders
    Well button may help or not, as Alain said. But i would personnally choose an interrupt routine or a tight loop with some PAUSEUS to do the job. I'm not a fan of this Button command so far...
    Any snip of what you tried?
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
