Easy LCD Contrast
Results 1 to 9 of 9
    California, USA
    Default Thanks Melanie!
    Well it's just amazing how simple and easy that is!
    Works Great!
    steve
    May 2007
    Will this work with a graphic LCD?
    If your LCD's Contrast is adjusted the same way as in a standard LCD, then yes. Just try it - you have nothing to lose but a few minutes out of your life.
    There's a lot of goodies buried in this forum, you just have to dig around a little.
    Good to have your vote of confidence Steve. *smiles*
    May 2007
    OK, thanks.
    Sao Paulo - Brazil
    Default Re: Easy LCD Contrast
    Hello Guys !
    I Know that this is an old post, but I would like to implement this solution on my project.
    I´m using a 16F877A @ 4Mhz, a 4x20 lcd and DT_Interrupts.
    I´m using the Timer0 for pulse counting, Timer2 as a 500 ms Time base and Timer1/CCP1 for pulses "on-time" reading.
    My doubt is : Can I use CCP2 to implement the contrast control as sggested by Melanie ? Or, as all timers are being used by the mains program, I can not implement it ?
    SHould I move to another PIC, 18F2520, for example ?
    Thank you !
    Sèrgio Pinheiro
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Need help with LCD number display.
  3. LCD will not start
  4. How to change contrast LCD?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 14:16
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 14:18
