Tris Register use.
Results 1 to 8 of 8
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    The TRIS Command in question is an assembly level command and not a PBP command.
    With the 877, if you write “TRISA=7”, for example, you are not using the TRIS command but loading the TRISA register directly. PBP takes care of all these issue for you so no worries.
    ASM Equivalent of what TRISA=7 does
    MOVLW 007h
    MOVWF TRISA
    ASM Equivalent using TRIS command - PBP does not do this (and this may not be supported on the 877?)
    MOVLW 007h
    TRIS PORTA
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2006
    Thanks for clearing that up for me!!
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Can anyone help a newcomer?
    By scopit in forum Schematics
    Last Post: - 20th October 2009, 10:23
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 22:54
