32 bit Division without DIV32
Results 1 to 5 of 5
    Are you using ON INTERRUPT, or ASM interrupts?
    If ASM, you don't need to worry about turning them off.
    CosMecc's Avatar
    CosMecc Guest
    Unfortunately I use ON INTERRUPT
    Well, if you can't disable the interrupts long enough to do a multiply and divide, then you shouldn't be using ON INTERRUPT. There are many statements that will take even longer.
    For Basic Language interrupts that won't interfere with DIV32, and won't wait for PBP, check this out.
    DT_INTS-xx
    http://www.pbpgroup.com/modules/wfse...p?articleid=19
    CosMecc's Avatar
    CosMecc Guest
    Thanks for this link, it is very interesting.
    Last Post: - 14th June 2016, 07:55
  2. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. 32 bit data displaying on LCD
    By selahattin in forum mel PIC BASIC Pro
    Last Post: - 15th September 2006, 13:33
    Last Post: - 6th March 2005, 01:07
