16f628a to 16f88 or 16f819
Results 1 to 8 of 8
    Jun 2006
    Default 16f628a to 16f88 or 16f819
    need to change something in the code;
    Jun 2006
    need to change something in the code which i have , from 16f628a to 16f88 or 16f819.
    we need more information... the existing code and PIC... and the target PIC #
    Jun 2006
    Quote Originally Posted by mister_e
    I have the code for the pic16f628a and work.
    I want to replace the 16f628a with 16f88 or 16f819
    	DEFINE LCD_DREG	PORTB	    'Selection of the port B
    	DEFINE LCD_DBIT 0	    'Selection one RB0 with RB3
    	DEFINE LCD_RSREG PORTA	    'RS on port A
    	DEFINE LCD_RSBIT 2	    'RS on RA2
    	DEFINE LCD_EREG	PORTA        'E on port A
    	DEFINE LCD_EBIT 3	    'E on RA3
    	DEFINE LCD_BITS 4	    'Mode 4 bits
    	DEFINE LCD_LINES 2	    '2 lines
    	DEFINE I2C_SCLOUT 1
    	PAUSE 500
    ' ** DEFINITION OF THE ENTREES - EXITS
    ' Exits I2C
    	SCL var PORTA.1                             ' SCL on RB1 (pine 18)
    	SDA	var	PORTA.0		' SDA on RB0 (pin 17)
    ' Boutons
    	UP	    var	PORTB.6		'increase the frequency (on RB6)
    	DOWN	var	PORTB.7		'decrease the frequency (on RB7)
    	CH_PAS	var	PORTB.5		'Change the step of synth (on RB5)
    	Input	UP			'Up and Down are entries
    	Input	DOWN
    	Input	CH_PAS
    Jun 2005
    Wisconsin
    Add the following to the top of the program:
    CMCON=%00000111 ' Disable Comparators
    ANSEL=%00000000 ' force RB6 and RB7 digital (16F88 specific)
    Jun 2006
    Quote Originally Posted by DynamoBen
    Already have : CMCON = 7 ' PortA = digital I/O
    Jun 2005
    Wisconsin
    So whats the issue? Is it not compiling?
    i bet on the internal osc... place the following at the top of your code
    OSCCON=%01110000 ' for 8MHZ operation
    OR
    OSCCON=%01100000 ' for 4MHZ operation
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 19:29
  2. 16F819 syntax ERROR
    By k-hirayama in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 01:40
  3. 16F88 is not the dream device I thought it was.
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 22:19
  4. 16f88 help
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2004, 18:50
  5. 4 line LCD with 16F88
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 10:06
