Can't compile
Results 1 to 3 of 3
Thread: Can't compile
    Lilmanmgf's Avatar
    Lilmanmgf Guest
    Default Can't compile
    I recently reformatted windows, and for some reason I am now unable to compile. When I attempt to conpile I receive this error,"Unable to compile toggle program.bas. The source directory is read only." I'm using pic basic pro, and microcode studio. My OS is windows xp, and the c:\PBP folder is read only, but I am unable to change that. In my previous install it was also read only, so I am at a loss. I tried reinstalling the compiler in a different folder, but it did not work.
    Jan 2006
    Istanbul
    As you know, since it is read-only directory your compiler can not create files to write into that folder and as long as it is read-only, you won't be able to compile.
    There can be two solutions.
    1. You may be having limited-access account in your OS. Make sure you have administrative privileges.
    or
    2. You may try moving PBP folder to C:\WINDOWS\PBP in which you should, most likely, be able to write. If not, you need to move PBP folder to a directory in which you must have the ability to write. If no folder gives you that, than you can try moving it to a zip drive and compile there. It will take longer to compile though.
    It sounds like you are either working on a school or public computer. Why are you not able to change read-only feature of that folder? Most likely it is because of the access you have.
    Lilmanmgf's Avatar
    Lilmanmgf Guest
    Thanks for the advise, but neither worked. This is my personal computer, and I'm running XP pro. Even logged in as an admin I am unable to change the folder properties. I might just reformat. Stupid windows...
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  2. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 08:18
  4. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 17:50
  5. Replies: 2
    Last Post: - 9th February 2006, 22:03
