interrupt handling faster than if's?
Results 1 to 14 of 14
    Jul 2006
    Would this work as the full code (forgive my ignorannce: I'm a newbie)?
    Transmitter:
    define HSER_TXSTA 20h
    define HSER_BAUD 2400
    cmcon = 7
    PORTSTATE var Byte
    LASTSTATE var Byte
    input PORTA.0
    input PORTA.1
    INput PORTA.2
    input PORTA.3
    PORTSTATE = PORTA & $0F
    If (PORTSTATE <> LASTSTATE) then
    LASTSTATE = PORTSTATE
    Hserout [PORTSTATE]
    Endif
    Pause 10
    Goto Main
    Receiver
    define HSER_CLROERR 1
    define HSER_RCSTA 90h
    cmcon = 7
    PortState VAR byte
    output PORTA.0
    output PORTA.1
    output PORTA.2
    output PORTA.3
    low PORTA.0
    low PORTA.1
    low PORTA.2
    low PORTA.3
    Hserin 20,Main, [PortState]
    PortState = PortState ^ $0F
    PORTA = Portstate
    Goto Main
    Jul 2006
    keithdoxey,
    what if I wanted to change
    "hserout [PORTSTATE]"
    to
    "hserout [WAIT("~"),PORTSTATE)"
    Would that work with the same code?
    Thank you.
    -Mike
    Feb 2003
    Quote Originally Posted by mbw123
    keithdoxey,
    to
    Thank you.
    -Mike
    Hi Mike, sorry for the delay replying, been on holiday for a few days
    The above should be "Hserout["~",PORTSTATE]
    Wait is only applicable for Hserin.
    In your previous post, instead of all the input and output commands just use the following
    Transmitter
    TRISA = %11111111 ' all pins as inputs
    Receiver
    TRISA = %11110000 ' A3-A0 as outputs
    PORTA = 0 ' turn off all ports
    HTH
    Keith
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2006
    Thank you very much for the reply.
    "Wait is only applicable for Hserin."
    Sorry. Stupid mistake by me. I meant
    HSERIN [WAIT("~"),PORTSTATE]
    Also would that slow down the code a lot?
    Thanks.
    -Mike
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
