Problem with LCD and Start Up
Results 1 to 14 of 14
    Jun 2006
    if at the top of code before define add the follow code
    pause 2000
    @ reset
    it's ok
    Iran
    please try this:
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 1
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 0
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    lcdout $fe,1,"Hello"
    LCD Connection
    Pin1=Vss: connect to ground
    Pin2=Vdd: connect to Vcc=5V
    Pin3=Vo: connect to middle pin of the POT(20K) to control brightness
    Pin4=RS(register select): connect to micro pins that specify in the software(RB1)
    Pin5=RW(Read/Write): connect to ground because we want to only write
    Pin6=E(Enable): connect to micro pin that specify in the software(RB0)
    Pin7 to 10: No connection
    Pin 11 to 14: connect to RB4 to RB7
    Pin15: connect to Vcc with a resistor(100 or 200 ohm resistor is good)
    Pin16: connect to ground.
    pin 16 and pin 16 are for backlights
    the other two pins of pot should connect to VCC and ground and you should connect the MCLR with a 4.7K or 10K resistor to the VCC.
    if your problem is not solve with this program you have another problem in other parts.
    Jun 2006
    thank you for answer , but i have make the circuit on pcb and i can't make changes
    be sure you set LVP to OFF, BOD to ON, PWRT to ON in your config fuses.
    I doesn't do magic, but it help in most cases.
    Jun 2006
    Quote Originally Posted by mister_e
    My pic is 16f84a not pic16F628a
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Paul's Theory - It sure sounds like to me that during the 0-3 second period after you turn off the power (and before you turn it on again), the power supply voltage drops low enough to reset the pic but not low enough to reset the LCD. After 4 seconds off, I am guessing the voltage decays enough to reset the processor AND the LCD - the LCD might be in the brown area until 4 seconds passes. You can:
    1)Use a scope to measure the voltage after you turn off the power and see what it does.
    2)Reset the LCD in software as partially described earlier in the week here
    http://www.picbasic.co.uk/forum/showthread.php?t=4851
    3)Change your power supply so that the voltage decays faster when the power is removed.
    4) Board change – move the power for the LCD (not backlight if you have one) to an open pin on the PIC and control it there. (I know your board is does but ... if you need to make a change later)
    the LCD show chinese
    Oh, I am guessing it is japanese you are seeing and not chinese - most controllers have japanese as a second set of data characters built in.
    Just my 2 cents worth
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    chinese or japanese, it's greek to me
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  5. LCD will not start
