I have a problem with below code and i don't know how to solve it.
When start the power on all works ok.But if power of for 1-3 sec and again power on the LCD show chinese and the program not work.If the power of is largest from 3 secs all works ok.
The pic is 16f84a.
Code:DEFINE LCD_DREG PORTB 'Selection of the port B DEFINE LCD_DBIT 0 'Selection one RB0 with RB3 DEFINE LCD_RSREG PORTA 'RS on port A DEFINE LCD_RSBIT 2 'RS on RA2 DEFINE LCD_EREG PORTA 'E on port A DEFINE LCD_EBIT 3 'E on RA3 DEFINE LCD_BITS 4 'Mode 4 bits DEFINE LCD_LINES 2 '2 lines DEFINE I2C_SCLOUT 1 ' ** DEFINITION OF THE ENTREES - EXITS ' Exits I2C SCL var PORTA.1 ' SCL on RB1 (pine 18) SDA var PORTA.0 ' SDA on RB0 (pin 17) ' Boutons UP var PORTB.6 'increase the frequency (on RB6) DOWN var PORTB.7 'decrease the frequency (on RB7) CH_PAS var PORTB.5 'Change the step of synth (on RB5) Input UP 'Up and Down are entries Input DOWN Input CH_PAS ' ** DECLARATION OF THE VARIABLES b1 var Byte b2 var Byte b3 var Byte b5 var Byte F1 var Word F2 var Word F3 var Word ADDR1 VAR Byte ADDR2 VAR Byte LOCK VAR Byte BAND VAR BYTE TMP VAR WORD TMP_LO VAR TMP.LOWBYTE TMP_HI VAR TMP.HIGHBYTE PLLBASE VAR WORD PLL VAR WORD RXPLL VAR WORD LO VAR RXPLL.LOWBYTE HI VAR RXPLL.HIGHBYTE PAS VAR BYTE '1=125kHz, 2=250kHz, 4=500kHz, 8=1MHz '*** INITIAL DATA *** ADDR1=$C2 ADDR2=$C3 'adress I2C of SDA5055 (ADDR1=$C0 , adress I2C of TSA5511) PLLBASE=720 'beginning with 45 MHz : 45 / 0,0625 = 720 PAS = 2 'pas of 0.0625 MHZ by defect PAUSE 100 LCDOUT $FE, 1 ' Clear LCD screen LCDOUT "TUNER 45-890 MHZ" ' post text during 2 second PAUSE 1000 EEPROM 0,[$70,$1c] 'initial data TMP =7280 ($1C70) corresponds to F = 500 MHz
