Series resistor when using weak pull-up
Results 1 to 13 of 13
    Mar 2005
    Denmark
    Question
    Hi Mister_e,
    I normally do the debounce in software.
    I have always used capacitors on inputs to suppres noise, but maybe they are not necessary?
    Sharky
    *Let's do it*
    i don't remind to have used capacitor on any of my design to supress noise when debouncing and handling could be done in software.
    Now if your buttons are far of your main board, it's another story.. but even in this case, i doubt capacitor will do some magic stuff.
    Maybe someone else have another point of view?
    Mar 2005
    Denmark
    Smile
    The touchpad that is connected to the board have 1.5 metre of cable.
    I have only used the capacitors and the serie resistors for products that needed
    to have an approval.
    But if I understand you right you also mean that the software debouncing will do the job.
    I think that I will just try to make the board without capacitors and serie resistors on the input's and see what happen when it goes to approval.
    Sharky
    *Let's do it*
    So in this case don't use the internal weak up. Use 1K-4.7 K instead. Safer.
    It's a long debate...'to use or not to use internal pull-up?'
    Mar 2005
    Denmark
    Post
    I have used pull-ups up to 100 K without problems.
    I know that you don't like weak pull-ups I remember from one of my other thread's, but I would really like do know what the problem about them should be?
    Because I really can see myself save some space on my PCB if I use the WPU's
    but if it is to risky I will of course not use them, I would just like to know why I
    should not use them!
    I have read that Melanie often use them even in industrial applications and I must admit that a lady that have a catsuit gives even a Shark some respect!
    Sharky
    *Let's do it*
    Jan 2006
    Istanbul
    ...and who is being the Shark here, I really wonder?
    so you should know a part of the story. I had some issue in car application, after i switch for external one i nerver ever had issue... this is why.
    BUT if it works for you... use it.
    Also, don't forget, if the unit is not always powered.... there's no pull-up, those pins comes 'floating' ...
    But i'm from the old school. I have my own fear that some don't have.
  1. Pull Up enabled and PWM question
    Last Post: - 7th September 2009, 08:21
  2. Weak pull Up 12F629
    By Lionheart in forum General
    Last Post: - 9th December 2008, 21:07
  3. switch on 1 weak pullup on portb?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 18:32
  4. 12F683 internal pull up
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th July 2008, 02:35
  5. 16f684 Porta.2 Instability
    By JDM160 in forum mel PIC BASIC Pro
    Last Post: - 5th November 2006, 02:38
