220 to 110 to 24 volts DC
Results 1 to 2 of 2
    Sep 2003
    Vermont
    Default 220 to 110 to 24 volts DC
    Good Morning!
    Here's an interesting one. A client needs a PIR unit to be used on 110 or 220 volts. We have a 220 to 110 Triac converter (standard wall wart circuit) to lower the voltage to run the 110 volt lights. Here's the problem...The PIR unit itself uses a resistor and capacitor to lower the 110 volts to 24 volts to power the circuitry. When the unit operates on 110 volt mains, it works fine. When the 220 volt mains are used with the converter, the resistor heats quickly to popcorn making temperatures! It is a 560 ohm resistor and obviously is disipating peak voltage across it, instead of the 110 volt average.I'd prefer to not have another switch to double the resistance in series with the PIR. Is there another way?
    Jan 2006
    Istanbul
    Hi Ron,
    Did you check the table in the following post?
    http://www.picbasic.co.uk/forum/showthread.php?t=3265
    Post Number #26.
    The table provides the values for correct Capacitor range both for 110V @60Hz and 220V @50Hz.
  1. DC volts and A/D converter
    By michel in forum Schematics
    Last Post: - 17th September 2008, 12:44
  2. Re: 24 volts dv from 12 vdc
    By Steve_88 in forum Off Topic
    Last Post: - 17th March 2008, 14:14
  3. me again
    By BobSpencerr in forum General
    Last Post: - 2nd March 2007, 00:15
