Hello,
This if my first time using the 16f688 micro and I am having trouble getting it set up properly to print to my Lcd in a 4 bit mode. I looked in the archives and couldn't find anything that deals with Lcd's using the 16f688. I tried to use CMCON0 = 7 to shut off the comparators but when I compile I get an error saying syntax error?
The Lcd does turn on but the top line is just all dark black blocks with light gray blocks on the bottom line. The Led flashes properly in the Mainloop. Can anyone here help me understand what I'm doing wrong for the Lcd. Any suggestions would be greatly appreciated.
jessey
'* Name     : Blink Led                                                        *
'* Author   : Jessey Montgomery                                                *
'* Includes :        *
'* Date     : November 15/th 2006                                              *
'* Version  : PicBasic Pro Ver 2.45, MPASM Ver 03.60, Using MicroCode Studio   *
'*          : 2.1.0.7, EPIC Version 2.46 beta programmer, PIC16F688-I/P 04470AY*
'                               |   16f688   |
'                   VDD+ (--->) |1         14| (<---) VSS-
'   RA5/TICKI/OSC1/CLKIN (<-->) |2         13| (<-->) RA0/AN0/C1IN+/ICSPDAT/ULPWU
'RA4/AN3/TIG/OSC2/CLKOUT (<-->) |3         12| (<-->) RA1/AN1/C1IN-/Vref/ICSPCLK
'            RA3/MCLR/Vpp(--->) |4         11| (<-->) RA2/AN2/TOCKI/INT/C1OUT
'              RC5/RX/DX (<-->) |5         10| (<-->) RC0/AN4/C2IN+
'        RC4/C2OUT/TX/CX (<-->) |6          9| (<-->) RC1/AN5/C2IN-
'                RC3/AN7 (<-->) |7          8| (<-->) RC2/AN6
'------------- Clear Each Port Before Setting The TRIS Registers --------------'
      Clear   ' Set all ram registers to zero
      PORTA = 0
      PORTC = 0
'--------------------------- VSS VDD MCLR Ect. Pins ---------------------------'
'     VDD +       '(pin 1)
'     VSS -       '(pin 14)
'------------------- SET THE TRIS  ------------------'
'-------------------- PORTA PINS --------------------'
      TRISC.0 = 0 '(pin 10) ...Blue.................Lcd Data bit 4
      TRISC.1 = 0 '(pin 9) ....White................Lcd Data bit 5
      TRISC.2 = 0 '(pin 8) ....Green................Lcd Data bit 6
      TRISC.3 = 0 '(pin 7)  ...Orange...............Lcd Data bit 7
      TRISC.4 = 0 '(pin 6)  ...Orange/Black.........Lcd Register select
      TRISC.5 = 0 '(pin 5)  ...Blue/White...........Lcd Enable bit
'-------------------- PORTC PINS --------------------'
      TRISA.0 = 1 '(pin 13) NOT USED
      TRISA.1 = 0 '(pin 12) NOT USED
      TRISA.2 = 1 '(pin 11) NOT USED
      TRISA.3 = 1 '(pin 4)  NOT USED
      TRISA.4 = 1 '(pin 3)  NOT USED
      TRISA.5 = 1 '(pin 2)  .......................Led
;       Configuration Bits
'  _FCMEN_ON                    EQU     H'3FFF'
'  _FCMEN_OFF                   EQU     H'37FF'
'  _IESO_ON                     EQU     H'3FFF'
'  _IESO_OFF                    EQU     H'3BFF'
'  _BOD_ON                      EQU     H'3FFF'
'  _BOD_NSLEEP                  EQU     H'3EFF'
'  _BOD_SBODEN                  EQU     H'3DFF'
'  _BOD_OFF                     EQU     H'3CFF'
'  _CPD_ON                      EQU     H'3F7F'
'  _CPD_OFF                     EQU     H'3FFF'
'  _CP_ON                       EQU     H'3FBF'
'  _CP_OFF                      EQU     H'3FFF'
'  _MCLRE_ON                    EQU     H'3FFF'
'  _MCLRE_OFF                   EQU     H'3FDF'
'  _PWRTE_OFF                   EQU     H'3FFF'
'  _PWRTE_ON                    EQU     H'3FEF'
'  _WDT_ON                      EQU     H'3FFF'
'  _WDT_OFF                     EQU     H'3FF7'
'  _LP_OSC                      EQU     H'3FF8'
'  _XT_OSC                      EQU     H'3FF9'
'  _HS_OSC                      EQU     H'3FFA'
'  _EC_OSC                      EQU     H'3FFB'
'  _INTRC_OSC_NOCLKOUT          EQU     H'3FFC'
'  _INTRC_OSC_CLKOUT            EQU     H'3FFD'
'  _EXTRC_OSC_NOCLKOUT          EQU     H'3FFE'
'  _EXTRC_OSC_CLKOUT            EQU     H'3FFF'
'  _INTOSCIO                    EQU     H'3FFC'
'  _INTOSC                      EQU     H'3FFD'
'  _EXTRCIO                     EQU     H'3FFE'
'  _EXTRC                       EQU     H'3FFF'
@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
'------------------------ Connections For Parallel Lcd ------------------------'
'-------------------------- To 16F688 Microprocessor --------------------------'
'--------------------------------- 4 Bit Mode ---------------------------------'
' LCD    Wire
'Pin No. Color             Symbol  Function               Connections To 16F688
' 1      Black              Vss    Ground ---------------Connect to -5V
' 2      Red                Vdd    +5V ------------------Connect to +5V
' 3      White / Black      Vo     LCD contrast 10K pot -Connect to center pad
'                                                       -other 2 pads to + & -
' 4      Orange / Black     RS     Register select ------Connect to pin  (6) RC4
' 5      Red / White        R/W    Read / write ---------Connect to -5V
' 6      Blue / White       E      Enable ---------------Connect to pin  (5) RC5
' 7     (not used)          DB0    Data bit 0
' 8     (not used)          DB1    Data bit 1
' 9     (not used)          DB2    Data bit 2
' 10    (not used)          DB3    Data bit 3
' 11     Blue               DB4    Data bit 4 -----------Connect to pin (10) RC0
' 12     White              DB5    Data bit 5 -----------Connect to pin  (9) RC1
' 13     Green              DB6    Data bit 6 -----------Connect to pin  (8) RC2
' 14     Orange             DB7    Data bit 7 -----------Connect to pin  (7) RC3
DEFINE LCD_EREG PORTC                   'Set LCD Enable port
DEFINE LCD_EBIT 7                       'Set LCD Enable bit
ANSEL = %00000000  ' no analog inputs
Led VAR PORTA.5 ' (pin 2)
'----------------------- Set Initial Time Variables -------------------------
PAUSE 2000 'wait for the Lcd to stabilize, show version screen below
          lcdout $fe,1,"     Blink      "
        lcdout $fe,$c0,"      Led       "
   GOTO Mainloop
Mainloop
     HIGH Led
       Pause 500
     Low Led
       Pause 500
goto Mainloop
