Compf
Results 1 to 3 of 3
Thread: Compf
    Moldava's Avatar
    Moldava Guest
    Default Compf
    is it correct to complement a variable (byte) the expression:
    var=-var ?
    thanks!!
    It's a question that can easily be answered with a bit of thought and experimentation...
    Firstly, (1) Does it Compile?
    If Yes, therefore there must be an answer... so Secondly (2) to find out what kind of answer we get you can write a simple program like so...
    DataA=10
    LCDOut $FE,1,#DataA
    DataA=-DataA
    LCDOut " ",#DataA
    and put in a series of numbers for DataA. If you don't have an LCD, you can use a series of consecutive EEPROM locations for your answers and read them back in your programmer.
    Actually this method answers a lot of questions that get posted on the forum.
    Oh... before I forget... the answer to your question is Yes.
    Moldava's Avatar
    Moldava Guest
    Thanks,Melanie...
    the third way i found is that what i was trying to do compiled and worked ,what made me really happy...but i will add an lcd to my prototype board,it will give useful information....
    Maneco
