Big 7 seg LED display
Results 1 to 32 of 32
    May 2007
    Indonesia
    Smile
    shahidali55 and all you guys in this forum......... thank's alot for technical information my job almost done now...
    once again thaaaaankkkkkkkkk's
    pic 16F628 with 4digits (10 inc) 7seg 12 Volt
    zhao hui
    May 2007
    Indonesia
    Lightbulb
    Here the final Schem that work fine, no software modification on PIC ..... just use the CMOS Inverter (4049 - Hex Inverter) to invert the logic.
    Jun 2006
    Bangalore, India
    Question Troubled Clock
    I'm having certain 'strange' errors in my digital clock.
    Processor = 16F84A @ 4 Mhz
    4 inch , 12 volt LED Display
    The schematic is almost the same as the one in the previous post.
    (A battery backup has been added)
    Problem 1:-
    The clock sometimes just 'hangs'. I think the oscillator stops or something.
    The display goes blank or most of the time only one digit on . . .
    Problem 2:-
    Timer0 is used for timekeeping (Darrel Taylor's Instant Interrupts).
    The clock suddenly stops incrementing time.
    i.e. the display multiplex routine keeps working as it can be seen that the all the digits on the display are displaying time.
    The thing is that the time never increments.
    I have programmed the colon between the digits to blink at 0.5 Hz.
    This blinking is controller by the time keeping registers mid byte which is kept updated by timer0.
    Since the digits keep showing a frozen time, and the colon stops blinking,
    Could it be that timer0 has somehow accidentally been disabled ? ? ?
    Attached Files :-
    clock.pbp - main file
    TMR0_int(ASM).pbp - interrupt handler
    Could someone please help me out ?
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. LCD will not start
  4. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
