Brian,
I see what you mean about the minimum power-up time of 10ms and the big power supply. Couple things you might try.
If you have an extra pin available? You could use that to power the LCD. It would allow a nice fast rise time independant of the power supply. It only draws 4-5ma for the logic. Power the backlight separately (if there is one).
Or, if you want to try the software initialization. Here's something I threw together.
The datasheet shows a slightly different init sequence than a normal HD44780. It doesn't even say which driver chip the display uses.
This routine follows the datasheet, and over emphasizes the delays, just in case. (16F only)HTH,Code:;---- Change these to match your hardware --------------------------- @ Device pic16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF DEFINE OSC 20 DEFINE LOADER_USED 1 DEFINE LCD_DREG PORTD ' Set LCD Data port DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus DEFINE LCD_RSREG PORTD ' Set LCD Register Select port DEFINE LCD_RSBIT 5 ' Set LCD Register Select bit DEFINE LCD_EREG PORTD ' Set LCD Enable port DEFINE LCD_EBIT 4 ' Set LCD Enable bit DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) DEFINE LCD_LINES 2 ' Set number of lines on LCD ;CMCON = 7 ' if needed ;ADCON1 = 7 ;-------------------------------------------------------------------- GOSUB LCD_INIT ' Do manual LCD Initialization LCDOUT "Hello World!" stop ;---- Manual LCD Initialization ------------------------------------- TempB VAR BYTE BUSdata VAR BYTE Send4Bit: @ MOVE?CT 1, LCD_EREG,LCD_EBIT ; Enable LCD @ MOVE?BB LCD_DREG, _TempB ; Put Data on the Bus R-M-W @ if LCD_DBIT == 0 ; Bus starts at 0 TEMPB = (TEMPB & $F0) | BUSdata @ else ; Bus starts at 4 TEMPB = (TEMPB & $0F) | (BUSdata << 4) @ endif @ MOVE?BB _TempB, LCD_DREG PAUSEUS 25 ; Keep enabled extra long @ MOVE?CT 0, LCD_EREG,LCD_EBIT ; Disable LCD Pauseus 50 return ;----------------------------------------- LCD_INIT: @ MOVE?CT 0, LCD_RSREG,LCD_RSBIT ; Start with RS LOW @ MOVE?CT 0, LCD_RSREG+80h,LCD_RSBIT ; RS is OUTPUT @ MOVE?CT 0, LCD_EREG,LCD_EBIT ; Start with Enable LOW @ MOVE?CT 0, LCD_EREG+80h,LCD_EBIT ; Enable is OUTPUT @ MOVE?CT 0, LCD_DREG+80h,LCD_DBIT ; Data Bus is OUTPUT @ MOVE?CT 0, LCD_DREG+80h,LCD_DBIT +1 @ MOVE?CT 0, LCD_DREG+80h,LCD_DBIT +2 @ MOVE?CT 0, LCD_DREG+80h,LCD_DBIT +3 PAUSE 1000 BUSdata = 3 GOSUB Send4Bit : pause 8 ; FunctionSet 4 times GOSUB Send4Bit : pauseUS 200 GOSUB Send4Bit : pauseUS 200 GOSUB Send4Bit : pauseUS 200 BUSdata = 2 : GOSUB Send4Bit ; 4-bit mode BUSdata = 2 : GOSUB Send4Bit ; 2-line, 5x7 BUSdata = 8 : GOSUB Send4Bit BUSdata = 0 : GOSUB Send4Bit ; Display OFF BUSdata = 8 : GOSUB Send4Bit BUSdata = 0 : GOSUB Send4Bit ; Display Clear BUSdata = 1 : GOSUB Send4Bit PAUSE 3 BUSdata = 0 : GOSUB Send4Bit ; Entry Mode Set BUSdata = 6 : GOSUB Send4Bit PAUSE 3 BUSdata = 0 : GOSUB Send4Bit ; Display ON BUSdata = $C : GOSUB Send4Bit @ MOVE?CT 1, LCDINITFLAG ; Tell PBP LCD is already Initialized return ;---------- END LCD_INIT --------------------------------------------
), it appears that you have the R/W pin hooked up to PORTD.6. But the ...
