LCD will not start
Results 1 to 40 of 50
    And a simple add at the bottom of the List...
    @ Device pic16F877A, HS_OSC, BOD_OFF, PWRT_ON, WDT_ON, PROTECT_OFF
    1. You Should also disable the LVP mode, sometime it could do some strange behaviour..
    2. Could be interesting to enable the BOD... safety sake.
    good luck!
    Default LCD still unreliable
    I have implemented Darrel's suggestions and they improve the situation but do not fix it. The LCD now starts about 50% of the time - up from less than 10% - but still not a solid solution.
    I think the problem lies (in part) in the power supply dV/dT at startup. Depending where in the mains cycle the unit is turned on, the power rise time can be from 20 - 90 mSecs. The data sheet implies the rise time should be under 10 mSecs and if that cannot be guaranteed, then a software reset sequence should be followed.
    Does anyone know the software sequence for 4 bit mode? The only examples I can find are both ambiguous and written for 8 bit mode which I cannot implement on this existing PCB with all i/o pins used on the PIC16F877A.
    Cheers
    Brian
    What happen if you tie the PORTB.3 to gnd via 10K (or less)?
    Did you tried to enable the BOD (brown out voltage) and disable the LVP (Low voltage programming) mode?
    If nothing work, maybe, you could add a little capacitor (0.1-1uF) between MCLR and GND... maybe.
    Schematic?
    Default LVP, BOD, etc
    Hi Mister-e.
    The PIC always starts. I know this because I have solenoids and switches and the switches always control the solenoids correctly. I think that rules out BOD or LVP issues. The 2 x 16 LCD always starts with the top row all black boxes and the lower row blank. When it starts properly, the LCD clears in about 500 mS and shortly afterwards the expected characters appear. When it does not start, the top line remains black and nothing appears on the lower line.
    I have tried 100 nf, 1uf and 10 uF as the MCLR capacitor with 10k to +5. Again the PIC always starts.
    The big 12 V 10 amp power supply is relatively slow to start and turning it on/off at the wall shows the LCD problem much more often than leaving the power supply on all the time and make/break the power line to the processor board. A scope shows the +5V rise time as 20-100 mS for on/off at the wall and under 1 mS for make/break to the 12 volt feed to the processor board. dV/dT is clearly part of the problem.
    A web search has turned up www.densitron.com and they have a discussion on timing aspects plus 4 bit and 8 bit modes. They make much of the tight timing restrictions between the Enable, RegisterSelect, data transitions and Read/Write lines and say this is a common problem with faster processors. sadly their app note is shot with typos and they do not define the pin functions (should RS be high or low during write? - they show it as both)
    I have the distinct feeling that PBP may be marginal with some brands of LCD at higher crystal speeds.
    Cheers
    Brian
    try...
    Start:
        Pause 1000
        LCDOUT $FE,1,"First"
        Pause 1000
        FLAGS=0
        LCDOUT $FE,1,"Second"
        FLAGS=0
        LCDOUT $FE,1,"Third"
    Loop:
        Goto Loop
    What happen?
    I heard that some LCD may need up to 2 second to start correctly... but i never had one in my hand
    Default Nope mister-e - that does not do it
    Hi mister-e.
    Your code, after fixing the start/loop and flag issues, does not work on power up. It does work after a MCLR reset but so do all my attempts.
    I am trying now to implement the full reset sequence in code.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    this might help - untried by me
    EDIT: My uploads do not appear to work?? - I put the file here as well
    http://www.cruxanalysis.com/temp/softwarereset.pdf
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
