Exact delay for a loop
Results 1 to 9 of 9
    Apr 2006
    Actually i just need it to use in my RPM counter program ,the loop which need to be executed is a repeated count loop that add a variable everytime a pin becomes LOW.(which i use a photosensor to scan the revolution per minutes for my DC motor).i use PIC16F877 and 4MHZ crystal for my application
    So for a certain time (1 minutes ) i know that how many times my motor slice has through my sensor ,by this way i can know the RPM of the motor,or is there any other way i can achieve that?Thanks.
    Feb 2005
    Kolkata-India
    Default Better to do with Interrupt
    Don't tell me you will be counting pulses for 1 minute and update your display. Too boring for a RPM counter. Why not check it every second and multiply the reading by 60. 1 sec refresh rate for your display. It is best to use Timer1 in counter mode and dumping the results every 1 second. For that you need a 1 sec timebase. If you are not accustomed with interrupts then this is high time to get going. Darrel has done a great job look here http://www.picbasic.co.uk/forum/showthread.php?t=3251 or http://darreltaylor.com/DT_INTS-14/intro.html and here http://darreltaylor.com/DT_INTS-14/elapsed.html for your timebase thing.
    Sougata
    Apr 2006
    Thanks sougata for the info,i'll try and work it out then .thanks!
    Apr 2006
    Hi there ,yesterday i had tried the timer interrupt function but ,i think i need one more interrupt for my sensor to detect (i use RB0 to trigger the pin) but i encounter 1 problem ,which is in my program i need 2 interrupt with differnt priority,any idea how to accomplish this ?thanks.
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  2. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
