Serial Programmer dead
Results 1 to 7 of 7
    Sep 2003
    Vermont
    Unhappy Serial Programmer dead
    Greetings list,
    I am using the MElabs serial programmer. It worked great for years, until I plugged it in this morning. No green light. I checked all power connections and regulators, but it all tests good. I also get a "no communications" box from the PC I am working with.
    Other than an 18F252 that decided to stop working, any ideas for trouble shooting?
    Ron
    How about the Crystal?
    Q1, Q2, Q3?
    Possible to have a faulty DB9 cable?
    Possible to have some break-link between the DB9 and the circuit?
    Broken pins on the dip socket?
    Do you have a way to check the com port? You might have a bad port.
    Jan 2006
    Istanbul
    Or may be they inserted a secret timer/counter inside the programmer to terminate the life of it; and now it is time to buy a new one.
    I am a great conspiracy theorist!
    Sep 2003
    Vermont
    Sorry, I haven't checked the list in a few hours. I replaced the crystal, and checked the com port. I normally get the green light on power up whether it's hooked up to the PC or not. Does the chip do a diagnostic on the transistors on power up?
    Sep 2003
    Vermont
    Otay... I spoke to Charles at MElabs. He told me that occasionally, the PIC252 just goes astray. About a dozen have, with no aparent cause. I ordered another chip and will update the list if this works. The board is so simple, I can't believe that it won't.
    Thanks for the input,
    Ron
  1. usb 24LCxx serial eeprom programmer
    By badrad in forum General
    Last Post: - 6th November 2008, 19:49
  2. Is My Programmer Dead
    By mikendee in forum Off Topic
    Last Post: - 19th March 2008, 17:59
  3. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  4. Wanted: MELABS serial programmer
    By AndrewC in forum Adverts
    Last Post: - 12th September 2007, 13:13
  5. MELABS Serial Programmer help
    By nigelstephens in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 22:01
