Dual Power Supply Design
Results 1 to 5 of 5
    Feb 2005
    Kolkata-India
    Default Dual Power Supply Design
    I fried my LAB power supply and really inspired to one controlled by a PIC. I need the following features:
    1. Dual Digital Variable +/- 0 - 30 Volts
    2. Display of V/I on the LCD (both arms single PIC)
    3. Tracking mode
    I plan to use the LM350 for its robustness. PWM controlled voltage reference for the Vref. Input of the regulator (with/without digital feedback correction perhaps)
    Where I am confused is the negative part of the supply. Measuring the supply ouput is okay but current....? If the opamps are on the PIC board powered by the positive half then common mode voltage is out of range. Level shifting accuracy is also a concern ?
    Any insights would be of great help
    Sougata
    Italy
    See this link:
    http://www.linear.com/currentsense/00-intoduction.pdf
    (At the bottom of this one page PDF you will see more links).
    Precision Circuit Monitors Negative Supply Current
    This current-sensing circuit monitors a negative power supply
    and provides a positive output voltage proportional to the load current.
    http://www.maxim-ic.com/appnotes.cfm...te_number/3855
    Best regards,
    Luciano
    Feb 2005
    Kolkata-India
    Default Thanks Luciano
    Luciano thank you for the links. The reference designs are really handy. However I was thinking of something very simple. Here is what I have in mind.
    1. A basic linear regulator with low side current sense amplified by an OP-AMP (LM358)
    2. Another block as above connected in series
    3. PIC supplied with the lower side so the higher side is refereced to the lower side.
    4. Simple resistor dividers to sense voltage. (Lower side first then higher side where higher side actual = higher side measured - lower side measured)
    5. Next I would try to implement a switching pre-regulator using one of the HPWM's of the PIC and possibily use the other PWM to generate a reference voltage. In tracking mode use another software PWM to offset main reference.
    I hope I would be able to complete it.
    Sougata
    Jan 2006
    Istanbul
    At the link Luciano posted, you can also find LTC2970.
    I did not check for 0-30V versions.
    Dual I2C Power Supply Monitor and Margining Controller.
    Here I attached two sample applications for your ref.
    <img src="http://img10.picsplace.to/18/LTC1.GIF" alt="Image Hosting by PicsPlace.to" >
    <img src="http://img10.picsplace.to/18/LTC2.GIF" alt="Image Hosting by PicsPlace.to" >
    Feb 2005
    Kolkata-India
    Default Thanks Sayzer
    Hi ,
    Thank you very much for the info. I didn't know such a chip exists. However my problem is somewhere else. The chip would definately not be available in Kolkata where I live. Even if I get it from somewhere else in my country it will be terribily costly (I suppose). Since this is not a commercial project I am not in a mood of spending much on it. Only fascinated by the idea of using a PIC and PBP in my design. So I will stick to legacy components. I would be using a inverting OP-AMP so that a -2.5V t0 +2.5V gives me a swing of 0 to 5 volts. I know I would be reducing the resolution but okay for this crude design. The other part is that I would not be using rail-to-rail OP-AMPs so for a full scale range of 0 to 30volts I would be generating a reference voltage using the PWM and scale it up. The statedgy is Keep It Simple. Your links were very helpful and I hope you can comeup with something very cheap using general components.
    Sougata
  1. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 01:12
  2. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  3. Need advice for 74VDC power supply
    By Christopher4187 in forum Off Topic
    Last Post: - 4th March 2007, 21:54
  4. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 08:07
  5. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
