Reading lcd information
Results 1 to 5 of 5
    Aug 2005
    I want to take the lcd out all together and just run the data lines straight into the pic. Then using the serout command, send the data to the pc. Im still learning pic basic pro. But im unsure how to capture the data and convert it to usable serial data, if its possible. I also thought of the same idea of reading the information back from the lcd using lcdin command.
    Thanks for the reply
    Sphere..
    Feb 2005
    Kolkata-India
    Default Try this
    Since you are new to PBP you might not be aware how a LCD works anyway. Try this link http://www.sxlist.com/techref/io/lcd.../djlcdsim.html or http://www.geocities.com/dinceraydin.../djlcdsim.html
    It will give you an insight on how a LCD works.
    Now you need to monitor the LCD enable and register select line too. Obviously you need a buffer inside the PIC since you serial out would be slower. While monitoring the port you can constantly loop around and then see if port!=port(buffer). This means a new data. Then dump it to the serial routine.
    Sougata
    Aug 2005
    Default Thanks
    Thanks alot for the info sougata.
    Sphere..
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
