Challenging Projects - IR Object Detector with Transformerless Power Supply
Results 1 to 11 of 11
    I was thinking of using a PWM signal for the LED. 12F683 could be handy here.
    Start the HPWM of x KHz, and use the internal timer to count in background. With a decent prescaler, it should reject most part of the ambient light.
    Just an idea... in theory it works.
    Jan 2006
    Istanbul
    Thanks for the details Sougata. I am definitely taking all info into consideration.
    And For 12F683, I will check the price and see if it is any advantage over using 12F675.
    I am currently working on this thing.
    More codespace
    1 Hardware PWM
    internal OSC up to 8 MHZ
    If i refer to digikey, the price difference for a single 8pin DIP is in the worst case 0.36$ mmm, i know, sometime it's enough.
    Jan 2006
    Istanbul
    Sometimes I think that I can even sell parts to Digikey.
    If you know what I mean.
  1. Transformerless Power Supply of 1A at 5Volts!
    By Ioannis in forum Schematics
    Last Post: - 10th September 2016, 22:17
  2. Transformerless Power Suppply
    By ERIK in forum Schematics
    Last Post: - 3rd September 2012, 16:08
  3. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 18:05
  4. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 08:07
  5. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 3rd July 2006, 00:13
