What is the easiest RTC chip of the moment?
Results 1 to 3 of 3
    Jan 2006
    Istanbul
    Quote Originally Posted by paxmowa
    They have so many, which is the best and easiest to interface chip in their list?
    Hi Steven,
    Pick the "cheapest one" or as the correct saying "least expensive" one.
    How would you determine which one is easier to interface?
    Based on what criteria?
    Mentor, Ohio
    Smile
    Hi Paxmowa,
    I have used the DS1337 on numerous projects. There have been previous posts on this forum that have listed the code for using this chip. It uses the I2C protocol. It is very important that you get a crystal with a 6pf load. The use of any other crystal will result in the time not staying correct. This chip only costs a couple of dollars and the crystal was less than a dollar from Digi-Key.
    Yes Maxim has many types of RTC's. You have to select one that will work for your application.
    BobK
  1. RTC chip or PIC?
    By flotulopex in forum General
    Last Post: - 28th July 2009, 22:02
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  3. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  4. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 18:33
