FOR...NEXT strange counting
Results 1 to 14 of 14
    SWITZERLAND (french speaking)
    Default FOR...NEXT strange counting
    Hello,
    I can't figure out how the FOR...NEXT count works.
    First my code, then my question.
    Duty VAR BYTE
    Duty = 0
    if duty = 0 then
       FOR Duty = 0 TO 254
          HPWM 1, Duty, 1000
          lcdout Dec Duty 'First read of "Duty"
          PAUSE 5
       NEXT
       lcdout Dec Duty 'Second read of "Duty"
    At the end of the FOR...NEXT execution, first read of Duty = 254. Right after the "NEXT" command, the second read of the variable Duty = 255.
    Why is this!?
    Roger
    Increse PAUSE 5 to PAUSE 500, it counts perfectly.
    Why you have 255 on the second LCDOUT?
    1   FOR Duty = 0 TO 254
    2      HPWM 1, Duty, 1000
    3      lcdout Dec Duty 'First read of "Duty"
    4      PAUSE 500
    5   NEXT
    Incrementation of Duty variable is done @ line #5, The condition to exit the for-next loop is done @ line #1. If >254, exit the loop. 255>254?
    I'm using this routine to switch ON the backlight of my LCD display, gradually but quite quickly (around 1 second). If I "PAUSE 500", it will takes ages to have the backlight fully on.
    As stated in the MicroCode help file, the max "duty" value can be 255. If I want to have the backlight fully ON, I should have 255.
    If the condition is "FOR Duty = 0 to 255", Duty will turn back to value 0 (zero) after the "NEXT" since it has been declared as a BYTE variable.
    Maybe, the best thing to do is to declare Duty as WORD sized...
    Nevertheless, the strange thing is that the Duty variable gets incremented by 1 when it exists the FOR...NEXT cycle.
    Roger
    Hi flotul,
    It won't matter that the Duty variable ends up at 0 when it wraps around. The HPWM will stay at the last DutyCycle it was set to "Inside" the FOR/Next loop. So you can go the full 0-255.
    It appears that you are using the "if duty = 0 then" statement to make the backlight only ramp-up once, when power is applied. Which also means that you have this section of code within the Main Loop of the program.
    If you take it out of the main loop and put it up at the top of the program, that section of code will only run once.
    Default Repeat...until
    I have my LCD-backlight controlled with two buttons; this is why it is in the main loop.
    The HPWM command accepts the duty value from 0 to 255.
    Actually, when the FOR...NEXT cycle is completed with a count up to 255, the value "wraps" from 255 to 0.
    But I track this value to prevent a second press on the same button (it's not nice to see the backlight switched OFF instantaneously and dimm up again when it was already ON - looks like a bug to the user).
    To get the HPWM at full range, I would count from 0 to 254 in the FOR...NEXT cycle and, when completed, add one more command to set the duty value to 255. This is not very "clean".
    Actually I found another way around. I use REPEAT...UNTIL. Now it works.
    I was just suprised to see how the FOR...NEXT cycle affects the count.
    Roger
    Since the for-next loop counting from 0 to 255 and the HPWM is inside the loop, where is the problem? At the end HPWM will be at 100% (255), the for-next will wrap to 0 since you have byte variable ant the loop will exit.
    Thats how a for-next works in the first place. Always exits when variable will pass the upper limit.
    Did I miss anything?
    I need to get a "HPWM 1, 255, 1000" final command with a Duty value of 255.
    Duty VAR BYTE
    Duty = 0
    FOR Duty = 0 TO 255
       HPWM 1, Duty, 1000
       LCDOUT $FE, 2, DEC Duty   'First read of Duty
    NEXT
    LCDOUT $FE, $C0, DEC Duty    'Second read of Duty
    When this FOR...NEXT loop is completed, the HPWM command will be correct ("HPWM 1, 255, 1000" - see first read of Duty) BUT Duty's value will be 0 (see second read of Duty).
    Even if the count is completed (Duty has reached 255), passing the last NEXT command will increment Duty by 1 and make it a 0.
    This is what happens with my 16F88 programmed with PBP. I never expected such a result.
    In my program, I use Duty as a reference to check if my LCD-backlight is fully OFF (Duty = 0) or if it is fully ON (Duty = 255).
    If Duty is 0, I'm allowed to press only button 'A'; if Duty's value is 255, I'm allowed to press only button 'B'.
    In other words, if Duty is 0, I don't want to allow a second press on button 'A'; I will only accept button 'B' and vice-versa if Duty is 255.
    The solution I found now is this one:
    SUBROUTINE:
        REPEAT
            Duty = Duty + 1
            HPWM 1, Duty, 1000
        UNTIL Duty = 255
    Roger
    Feb 2003
    Alternatively you could add the following line
    FOR Duty = 0 TO 255
    HPWM 1, Duty, 1000
    NEXT
    Duty = Duty-1
    Which would put it back the the final value inside the For/Next loop
    If you are also dimming down then do the opposite
    FOR Duty = 255 TO 0 STEP -1
    HPWM 1, Duty, 1000
    NEXT
    Duty = Duty+1
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thank you keithdoxey,
    It is not about to find a solution to make it work; it is about how the FOR...NEXT loop counts.
    There are lots of differents solutions to solve my problem and I wonder how many people noticed this stange loop counting behaviour.
    Roger
    Feb 2003
    Quote Originally Posted by flotulopex
    I think it is the same in any language.
    you specify the start and end points for the count and optionally the step size.
    the count starts at the specified start value then adds (or subtracts) the step value. It is then tested to see if it is within the range specified at which point the actions are executed. Once outside the specfied range it exits the for/next loop. This means that the value has to have changed from the last time the loop code was executed.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Hi Flotul
    As I stated at #6 there is no strange behaviour. It is just the way for-next loops work in every version of Basic. Inside the loop the result is absolutely correct. Outside is expected to be +1 or -1 depending on the step of counting.
    I see nothing strange here.
    Other way to make a loop like While-Went or Repeat-Until use different counting methods.
    While-wend for example, first checks, then executes. For-Next, first executes then checks.
    OK i'll try another explanation
        For Variable=0 to 255
            Pouet pouet
            next
    The test is done at the FOR TO NEXT line, the incrementation is done at NEXT line.
    So at the end the value=256... wich is really hard to fit in a BYTE variable. Hence it gives 0
    Change your var to a WORD too see what's happen now.
        Repeat
            Pouet Pouet
            Variable = Variable +1
            Until Variable = 255
    a Repeat Untill loop do the test at the end... so this why it worked
    Thank you All,
    All your explanations are absolutely clear.
    Roger
    Hi Flotulopex. The FOR - NEXT is confusing to me too. I use a different routine from a basic compiler I used a long time ago. This is a snip from a motor speed controller that controls the speed of an electric cart. At the start of the program, LEFTRAMP is made 0. If the speedpot is reduced while running, it will also ramp down.
    LEFTON: 'TURNS ON LEFT MOTOR FOR RIGHT TURN
    ADCIN 2, SPEEDPOT
    IF LEFTRAMP < SPEEDPOT Then LET LEFTRAMP = LEFTRAMP + 1
    IF LEFTRAMP > SPEEDPOT Then LET LEFTRAMP = LEFTRAMP - 1
    Pause 1 'CONTROLS THE RAMP-UP DELAY
    HPwm 1,LEFTRAMP,15000 'PWM OUTPUT DUTYCYCLE LIMITED TO SPEEDPOT
    GoTo LEFTON
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 04:52
  2. Remain counting while sending out a pulse
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 10th January 2007, 15:51
  3. Strange behaviour from PIC16F877 on TMR0
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 19th August 2006, 01:31
  4. continious counting process (capture)
    By asynch in forum General
    Last Post: - 17th February 2006, 07:42
  5. Strange ASM file
    By barkerben in forum General
    Last Post: - 29th November 2004, 18:54
