inaccurate frequency using TMR1 PI18F452
Results 1 to 15 of 15
Threaded View
  1. #13
    Jan 2006
    Istanbul
    Let me edit a small part.
    @Timer1 = TMR1L
    Timer1  VAR  WORD EXT
    Disable
    miint:
    	IF PIR1.0 = 1 THEN
    		T1CON.0 = 0
    		Timer1 = Timer1 + FRECUENCIA
    		T1CON.0 = 1
    		IF ARRANCA_MOTOR = 1 THEN
    			PORTC.5 = 0	'PULSO DE STEP
    			PORTA.5 = 0	'SALIDA PARA SHAFT
    			PORTA.5 = 1	'SALIDA PARA SHAFT
    			PORTC.5 = 1	'PULSO DE STEP
    			IF EMULACION = 1 THEN TRIGGER = ACTIVA_PRESENCIA
    	PIR1.0 = 0
    	'**************** INTERRUPCION POR TIMER 0  **************
    salida1:
    	Resume                 ' retorna al programa principal
     	Enable
  1. Code Measure Frequency by TMR1
    By blinkstar88 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 10:51
  2. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 19:11
  3. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  4. HPWM10 Frequency Updating
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 13:30
  5. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
