1.5 volt power.
Results 1 to 7 of 7
Thread: 1.5 volt power.
    Sep 2003
    Vermont
    Thank you sarma,
    My board space was limited, so I used the Maxim 1794 DC-DC converter. It is in a SOT package, and even has it's own zero crossing detector switch, which eliminated the Schottky diode. It will start at .8 VDC and draws only a few microamps when not loaded down. Check it out...
    Ron
    Italy
    Hi Ron,
    Is the part number MAX1794 correct?
    I believe the correct part number is MAX1724.
    MAX1724:
    http://datasheets.maxim-ic.com/en/ds...22-MAX1724.pdf
    Best regards,
    Luciano
    Quote Originally Posted by Luciano
    Hi Ron,
    MAX1724:
    Best regards,
    Luciano
    Whew! I spent the better part of a 1/2 hour looking for the 1794. I didn't find it either. Thanks for the info on the 1724.
    JDG
    Sep 2003
    Vermont
    Hi Ron,
    MAX1724:
    Best regards,
    Luciano
    Oops! I transposed the number on my notes. That's the one.
    Sorry,
    Ron
  1. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. Decent 24 volt Pic power supply
    By rwskinner in forum Schematics
    Last Post: - 18th December 2006, 13:27
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
  5. Help from EE's on Power Meter (AN220)
    By SteveB in forum Off Topic
    Last Post: - 27th November 2006, 08:05
