Assuming that you already set your pins as inputs & outputs; a code as below should work.
edit : Also, is it a push-pull button or a holder switch?
Code:OUTPUT PORTB.3 'make pin an output pin OUTPUT PORTB.4 'make pin an output pin INPUT PORTB.5 'make pin an input pin GreenLED VAR PORTB.3 'assign a name to the pin RedLEd VAR PORTB.4 'assign a name to the pin Emergency VAR PORTB.5 'switch pin Begin: GreenLED = 0 'Initially OFF. RedLEd = 1 'Initially ON. main : IF Emergency = 1 Then 'Someone pushed the button. WHILE Emergency = 1 : wend 'Wait for finger release. TOGGLE GreenLED 'Change the status. TOGGLE RedLEd 'Change the status. ENDIF GOTO main
