PIC18F452 Compile Problem
Results 1 to 11 of 11
    Hi Scott,
    No problem. Shoot me an email. I'll just respond with the .hex file in .zip
    format back to you.
    Let me know the osc frequency, and whatever config fuse settings you
    prefer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    inteco's Avatar
    inteco Guest
    Scott,
    Instead of using ICD-U software, try download and use MACH X software. But you need to use the newest ICDU software, and upgrade the firmware first prior of using the the new MACHX software.
    Downloading step :
    1. Open MACH X
    2. Browse /open the *.hex generated by PBP
    3. in the MACHX click CONFIGURATION/ID, then click on any
    configuration hex number located in the left side row.
    Do NOT change the number just click it, as if you want to change.
    4. Then click SAVE AS button, save the *.hex to a new name
    (whatever.hex)
    5. Then click BURN CHIP
    6. Trust this would work.
  1. DT's instant interupts compile problem
    By comwarrior in forum General
    Last Post: - 18th October 2009, 20:30
  2. USB compile problem
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2008, 17:39
  3. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  4. 18F452 compile problem
    By pcbb in forum General
    Last Post: - 21st April 2007, 03:16
  5. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
