PIC18F452 Compile Problem
Results 1 to 11 of 11
    Few things are missing in your post:
    1. Wich message you have?
    2. Are you using MPASM?
    3. Wich programmer?
    Mar 2005
    Seem to get everything to compile without warnings. I am using MPASM and the programmer I am using is the ICD-U40. I know I know!
    Jan 2006
    Istanbul
    In your programmer, do you have an option of reading actual configuration fuses and re-inserting it into the hex file?
    Hi Scott,
    MPASM doesn't like it when you have config fuse settings in your source code,
    and in the PBP device header file.
    To insert them in your source you need to comment them out in 18F452.inc.
    Open 18F452.INC in your PBP directory, comment these out, save it, then add
    config fuse options in your source.
            LIST p = 18F452, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F452.INC"   ; MPASM  Header
            ;__CONFIG    _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L
    Now you can drop them into your source;
    asm
    endasm
    I'm not familiar with the device programmer you're using, but make sure you
    always erase the target before trying to program it.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2005
    Unhappy
    Bruce,
    The ICD-U40 is the CCS USB Programmer!
    I have tried all that everyone suggested but it will not program the PIC18F452. It may be my version of PICBAsic Pro 2.43. I may rewrite the code with the CCS Compiler. I hate to start over since I have had everything working in PICBASIC Pro for the PIC16F877.
    Thanks anyway,
    Scott
    Hi Scott,
    Bummer. Have you contacted CCS? I beleive they have firmware updates for
    their programmers. May or may not help, but I don't think there's any reason
    to port over from PBP to CCS if it's just a problem with the programmer.
    I know people get tired of hearing this one, but it's also a good idea to keep
    PBP & MPLAB updated as well.
    If it would help, I could send you a known working .hex file for a 452 compiled
    with PBP. If it doesn't go in, then at least you're 100% sure it's your device
    programmer, and CCS should be able to get you sorted out on that one.
    I like/use the CCS compilers, but I don't use their programmers. MeLabs U2 is
    all I use now. All my other programmers are gathering dust...;o}
    -Bruce
    tech at rentron.com
    Bruce, And i feel one of those is obsolete and no longer on the market
    His name begin with W and you already carry those in the past.
    Mar 2005
    Hi Bruce,
    I have been looking at upgrading but timing is an issue here! I would like to test your sample .hex file just to see if it works. I will test this tonight and let you know. At least I will hopefully know were the problem is!!!
    Thanks again,
    Scott
  1. DT's instant interupts compile problem
    By comwarrior in forum General
    Last Post: - 18th October 2009, 20:30
  2. USB compile problem
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2008, 17:39
  3. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  4. 18F452 compile problem
    By pcbb in forum General
    Last Post: - 21st April 2007, 03:16
  5. problem whit pic18f452
    By ocastrillo in forum General
    Last Post: - 9th March 2007, 17:18
