Dealy in turn ON of PIC18F452
Results 1 to 2 of 2
    genesis's Avatar
    genesis Guest
    Smile Dealy in turn ON of PIC18F452
    Hi...
    I am using PIC18F452 and I have connected (MCP130"Microcontroller supervisory circuit") in the MCLR pin No.1 of microcontroller.
    When Vdd 5V is given to the controller ,it takes 270 ms to turn ON the microcontroller.
    How to minimize the delay and quickly turn ON (less than 50 ms) the controller after Vdd=5V is given.
    Please suggest some tips, related documents.
    Feb 2003
    I suggest reading the datasheet for the chip you are using.
    If you are getting the PIC running in 270mS you are doing well. 50mS will not be acheivable using that chip.
    From the first page of the datasheet.....
    2001 Microchip Technology Inc. DS11184D-page 1
    MCP120/130
    FEATURES
    • Holds microcontroller in reset until supply voltage reaches stable operating level
    • Resets microcontroller during power loss
    • Precision monitoring of 3V, 3.3V and 5V systems
    • 7 voltage trip points available
    • Active low RESET pin
    • Open drain output
    • Internal pull-up resistor (5 kΩ) for MCP130
    Holds RESET for 350 ms (typical)
    • RESET to VCC = 1.0V
    • Accuracy of ±125 mV for 5V systems and ±75 mV for 3V systems over temperature
    • 45 μA typical operating current
    • Temperature range:- Industrial (I): -40°C to +85°C
    DESCRIPTION
    The Microchip Technology Inc. MCP120/130 is a voltage supervisory device designed to keep a microcontroller in reset until the system voltage has reached the proper level and stabilized. It also operates as protection from brown-out conditions when the supply voltage drops below a safe operating level. Both devices are available with a choice of seven different trip voltages and both have open drain outputs. The MCP130 has an internal 5 kΩ pullup resistor. Both devices have active low RESET pins. The MCP120/130 will assert the RESET signal whenever the voltage on the VDD pin is below the trip-point voltage.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  2. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 22:27
  3. Help with PIC project
    By davekav in forum General
    Last Post: - 17th April 2008, 23:15
  4. Interface for 16f818
    By davekav in forum Serial
    Last Post: - 17th April 2008, 11:33
  5. LCD will not start
