external oscillation
Results 1 to 17 of 17
    Sep 2006
    Default external oscillation
    Hello,
    I would like to know if it possible to create 20KhZ external frequency with Pic chips, lets say the pic16f88. I did not find anything on google on such a thing.
    thank you
    ken
    Jan 2006
    Istanbul
    If what you want is to generate 20Khz frequency using 16F88, then sure you can do it by using PWM feature of this PIC.
    For 20Khz at 4Mhz, using 1:1 prescaler, PR2 should be 49.
    At 20Mhz, 1:1, PR=249.
    mister_e, pls correct me if I am wrong
    Yup PWM is the way to go. You can use the PBP HPWM or setting the PIC register as Sayzer said.
    Quote Originally Posted by Sayzer
    I got the same results
    Sep 2006
    I got it going with a 4Mhz oscillator. Here is the program.
    I wanetd to use the 20Mhz oscillator. and it do not work. I change the 4 to a 20 in the program and changes the crystal and the capacitor to 22pF and it is not oscillating, anybody knows why. is there a command I nee to do ?
    Define LOADER_USED 1
    DEFINE OSC 4 'Using 4MHz oscillator
    TRISB = 0
    loop: FREQOUT PORTB.1,10000,20000 ' Turn on PORTB for 1- sec at20Khz
    Pause 100 ' Delay for .5 seconds
    Goto loop ' Go back to loop and blink LED forever
    Sep 2006
    ok added this line :
    @ DEVICE HS_OSC
    and now it works
    Sep 2006
    I am trying ot get a sin wave at the output. From the manuals of picbasic pro, they say to add a low pass filter, I did this, it dos remove the extra noise, but it does not make it a sinwave. Anybody know how to make it a sin wave ?
    ken
  1. Replies: 1
    Last Post: - 28th January 2010, 23:15
  2. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 19:11
  3. How to use an external oscillator
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 5th February 2008, 15:19
  4. External Control Lines
    By weirdjim in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 20:29
  5. switching external vref+ and vdd vref
    By alejandro_halon in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 21:13
