Using DS18S20 vs DS1820 with 4x7 LED Displays
Results 1 to 15 of 15
    Jan 2006
    Istanbul
    Default Using DS18S20 vs DS1820 with 4x7 LED Displays
    Hi there,
    Since DS1820 temp chips are replaced by DS18S20, we get a slower convertion time.
    500ms vs. 750ms.
    When using 18S20 (or 18B20), I get a blank on LED display while the convertion is in progress while I get no blank display using 1820.
    Any idea how to overcome this issue?
    Been awhile, but if I remember correctly, you can send a "Start Conversion", then just check the busy flag on each loop. When it's done, goto a subroutine to get the result.
    Most examples that I've seen just sit in a WHILE/WEND or similar loop waiting for the busy flag without doing anything else. 3/4 of a second is a long time.
    Jun 2005
    Wisconsin
    Quote Originally Posted by Darrel Taylor
    I use a timer to send the start conversion every second. Then I check the flag via a loop, based on the flags status I either retrieve the info and update my display or continue on with other things. While/Wend wastes too much time for me.
    Jan 2006
    Istanbul
    Thanks for the info DT.
    Let me work on that bit.
    sayzer,
    Are you using Bruce's code with the SLED4C, or independant 4 digit seven segment displays.
    I was just thinking that if it's the SLED4C, it might be a different problem. Don't know what, but it wouldn't blank no matter how long it took for the conversion.
    Just curious.
    Jan 2006
    Istanbul
    ...Are you using Bruce's code with the SLED4C, or independant 4 digit seven segment displays...
    Thanks DT.
    I am using Bruce's code with independent 4-digit Seven segment displays (two displays; 8 digit).
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
  5. LCD will not start
