Remote Control receiver - input source switching
Results 1 to 11 of 11
    Jan 2006
    Default Hi,
    I just finish my. using part of this proyect.
    h t t p : //www.web-ee.com/Schematics/VSwitch/vswitch.htm
    the only part i change was the software, i use some ir RC5 library from this book Experimenting with the PicBasic Pro compiler.
    h t t p : //developersbooks.com/ebooks/viewbook/38/17/1.html
    now im working to add some OSD.
    i hope this help.
    Jul 2004
    Madrid-Spain
    Quote Originally Posted by cesarman
    i hope this help.
    I am sorry to say that I do have this book, it was my first one about PicBasic Pro, and there are no RC5 routines in it. Unless there is a new edition and they have been included. Can you check that?
    I have been looking for an easy to use RC5 library and haven't found any.
    Thanks in advance
    Carpe Diem
    Jan 2006
    mmm, sorry you rigth only for sony protocols. no RC5, well the only basic compiler is proton. Version 3.X, has RC5 fuction. Tested
    Example
    Device = 16F877
    RC5IN_PIN = PORTC.0 ' Choose the port and pin for the infrared sensor
    DIM RC5_WORD as WORD ' Create a WORD variable to receive the data
    DIM RC5_COMMAND as RC5_WORD.Lowbyte ' Alias the COMMAND byte to RC5_WORD low byte
    DIM RC5_SYSTEM as RC5_WORD.Highbyte ' Alias the COMMAND byte to RC5_WORD high byte
    ALL_DIGITAL = ON ' Make all pins digital mode
    Cls ' Clear the LCD
    While 1 = 1 ' Create an infinite loop
    Repeat
    RC5_WORD = RC5In ' Receive a signal from the infrared sensor
    Until RC5_COMMAND<> 255 ' Keep looking until a valid header found
    Print at 1,1,"SYSTEM ",Dec RC5_SYSTEM," " ' Display the SYSTEM value
    Print at 2,1,"COMMAND ",Dec RC5_COMMAND," " ' Display the COMMAND value
    Wend
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. DTMF and PIC for Remote Control
    By doggitz in forum mel PIC BASIC Pro
    Last Post: - 30th March 2010, 12:42
  3. Newbie remote control question?
    By Clodoaldo in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 18:20
  4. Please help ? RF Remote Source code
    By sorasit46 in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:40
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 16:13
