breadboard and hserout interference?
Results 1 to 10 of 10
    my bet is more about possibility of a buffer overflow.
    Try this one for the transmitter
    Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h
    ' Set baud rate
    DEFINE HSER_BAUD 2400
    cmcon = 7
        If (PORTA.1 = 0) then
            hserout ["1"]
            while PORTA.1=0 : Wend : pause 500
        if (PORTA.1 = 1) then
            hserout ["2"]
            while PORTA.1=1 : wend : pause 500
    what about your crystal speed? Config fuses? Schematic?
    Jun 2005
    Wisconsin
    To answer your question directly, I have done a lot of serial projects on breadboards and never had an issue.
    Sep 2003
    Vermont
    Quote Originally Posted by mister_e
    ' Set baud rate
    cmcon = 7
            hserout ["1"]
            hserout ["2"]
    It sounds like you only want to send a character on the state change of the switch. Use a bit variable such as current_state for the last known state.
    This way, you won't hang the program up waiting for the switch to change.
    Read_switch:
    if (PORTA.1= current_state) then goto main ; No change goto main program
    hserout [PORTA.1 + $30] ; Make the switch value the ASCII equivelent and send it.
    current_state = PORTA.1 ; Current_state = switch value
    goto main ; How neat is that?!?
    Talking
    for sure i need to sleep!
