Using Sound cmd on 16F88
Results 1 to 24 of 24
    Gator_sound's Avatar
    Gator_sound Guest
    BigWumpus,
    Do you have a part number or a particular place where I can purchase a ready made piezo-beeper? thanks.
    Hangover, Germany
    Digisound F/UCW 03 or ...06
    Gator_sound Guest
    Hi everyone,
    I finally got a PIC with HPWM. Is there anything else I have to setup aside from the ccp1con? Thanks
    Jan 2006
    Istanbul
    Which pic is it?
    PR2, T2CON are others most likely.
    Gator_sound Guest
    Hi sayzer,
    its a 18f1320 with the HPWM without the HPWM 16f88. thanks
    Jan 2006
    Istanbul
    Hi Gator,
    18f1320 has "Enhanced CCP module" which is more complicated then the others.
    Also it has four PWM outputs, P1A through P1D, and this makes CCP1CON register more complicated to be set.
    It is over my head, and I have zero experience in it. I am eager to learn it though as I will have to work with 6pwm channels soon.
    May be our highly experienced members can give you hand on that? and you can post the ongoing progress here...
    Gator_sound Guest
    Its finally working. The code (sound command) was right but not sure why it did not work. I changed the output pin and now its working. Thanks for those who have replied. I really appreciate it.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  3. Alfat Sd/mmc
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 24th July 2006, 06:10
  4. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 14:08
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 01:44
