Using Sound cmd on 16F88
Results 1 to 24 of 24
    Knowing your piezo-speaker resonnant frequency you should be able to produce a louder sound. Use a simple High/pauseUS/low/pauseUS loop or HPWM to produce the right resonnant frequency.
    Experimentation will give you the right resonnant frequency, kinda piezo g-spot. Closer you are, louder it is
    Jan 2006
    Istanbul
    Quote Originally Posted by mister_e
    ... piezo g-spot. Closer you are, louder it is
    Hi Steve,
    Is it true in other cases, too?
    LMAO! i guess it would depend of the hardware
    Gator_sound's Avatar
    Gator_sound Guest
    Thanks for the reply sayzer and mister_e. I've tried both of your methods but but just the capacitor is louder then the npn transistor unless I am connecting it incorrectly. Any other suggestions? Thanks again for your ideas and help.
    Provide your piezo part # so we could try to find the g-spot of it !
    Most piezo's oscillate at their resonant frequency when a DC voltage is applied.
    The SOUND command outputs a complex form of PWM that is intended to produce a sudo Sine Wave when used with a Low Pass Filter. This won't allow the piezo to oscillate very well at all.
    To get the Loudest sound, use sayzer's circuit (with 12V) then set the pin HIGH. (Don't have your ear too close or you'll lose it).
    Of course, I wouldn't want to wake up with that sound. It's more like a Smoke Detector high pitch blast.
    If you want a better sound using the SOUND command, run it through a low pass filter, then amplify it, then use a normal speaker instead of a piezo.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  3. Alfat Sd/mmc
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 24th July 2006, 07:10
  4. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 02:44
